Anyone running 325/60R18s?
Old May 27, 2023 | 08:55 PM
Gznutz's Avatar
2010 Benefactor Dubsta
If so please post pics and fitment information. Considering this size in an AT.
Old May 29, 2023 | 08:10 PM
Texas E63's Avatar
Built 2008 G55 & one big 80 Series LandCruiser !
I ran those on my G55 to start with 50mm Spring spacers..... now running 325/65's ( 35" od) with a 4" lift... what year model are you looking to run these on any nay mods/ inten
ded use ?
these are the 325/65's with full 4" of lift and supporting mods.
E
Old May 31, 2023 | 12:28 AM
Gznutz's Avatar
Originally Posted by Texas E63
I ran those on my G55 to start with 50mm Spring spacers..... now running 325/65's ( 35" od) with a 4" lift... what year model are you looking to run these on any nay mods/ intended use ?
Looks meaty! Where did you get the spacer lift installed, or did you do it yourself?
I have a 2010 G55 with G63 springs, 35 mm wheel spacers, & OEM 18x9.5ET50 wheels. Plan on doing a 40mm front/30mm rear spacer lift for clearance and leveling things out.
Offroading done at Hidden Falls Park in Austin.
Old May 31, 2023 | 05:04 AM
Texas E63's Avatar
I did the lift in stages - a blend of JWO springs, Konis and then A batch of Eurowise parts to get t he alignment all dialed.... the 40mm spring spacers are a great way to go and will allow for a 325/60 nicely....I'll dig up pics of just that setup tonight and can share.
For stance, you can run another 50mm wider or so by going to an Alpha rim (18x9 et 25 plus still running the 30mm spacer) or similar and still have no rubbing on full suspension cycle.
Hope to have the G back to Houston Mid-June should you want to check ride quality on the JWO springs, and /or the Koni's - I'm out in Fulshear when in TX. Any other mods planned ?
Cheers
E
