90,000 Mile service is Dealer taking me for a ride????
Old Dec 12, 2024 | 07:46 PM
TuLsaViPeR's Avatar
C230, G550
At 90K mile service is the spark plug change included?
Dealer is trying to charge me an extra $1000 to change the spark plugs, but Is also charging me 4K for a 90K mile service B. With taxes and fees the Bill looks like it's 6K. Some of this stuff looks like I'm being double charged.
To be honest I'm totally confused now and I feel like he's trying to take me for a ride. The Original Service B invoice was $2600. Now I'm close to 6K. Half the stuff on the list looks like Inspections.
Plus recommendations he's trying to charge me 8K for a 2013 G550 90,000 miles. Of course Id never agreed to that. BUT I give him an A for effort.
[img alt="Current Estimate
"]https://cimg0.ibsrv.net/gimg/www.mbworld.org-vbulletin/1120x2000/screenshot_20241212_164744_6fee83a7600b9b3ff33d77c 16e5ec1b81142a030.png[/img]
Current Estimate
Current Estimate unapproved changes
Current Estimate
Current Estimate
Old Dec 12, 2024 | 10:05 PM
shiann's Avatar
2005 G55K
It sounds like a lot of extras, but really depends on if your G really needs it or not.
Rear brake pads - this price is high for sure since it's only the pads. good chance you'll need rotors too, which pads + rotor parts alone are ~$600
Rear tires - I would check this and replace all 4 at the same time to avoid any differential problems - costs will vary with what tire you go with
No idea what the oil filter housing reseal (with heat exhanger) is - will need a breakdown of what that involves
centrifuge cover? this is rear cam breather cover - they're charging a lot of labor there for an inexpensive part.
Service B is nothing more than an oil change, check on all fluid levels, replace filters, and general check on other things - should definitely skip and do it yourself
Quick Service 01 - no idea what this is
Alignment - skip this and go to another shop for half the cost.
Spark plugs - M273 kit is cheap and easy - skip for sure or find an indy
headlight bulbs - they do take some time to replace, but can be done in 30 minutes or so. depends what bulbs you replace them with. Bulbs are ~$100 each, so you can do the math.
Old Dec 13, 2024 | 06:15 AM
Solihull's Avatar
G500
You are absolutely being taken for a ride from the Stealer. Find an Indy and cut that bill way down.
Old Dec 13, 2024 | 06:56 AM
xxaarraa's Avatar
Multiple
What they are quoting for Oil filter housing reseal is actually quite reasonable. I replaced my oil filter housing at home and it was easily 20+ hours of labor. Otherwise, I agree, I would do the rest of the items they are quoting myself for much less.
Old Dec 13, 2024 | 07:15 AM
streborx's Avatar
Top Answer: 1
G550
$632 for mounting and balancing 2 tires, tires not included? My tire dealer mounts, balances and installs 4 tires at no additional cost to the tires I buy. This dealer is a thief.
Old Dec 13, 2024 | 07:53 AM
chassis's Avatar
2017 GLE350 4MATIC
Go to an indy or DIY.
Old Dec 13, 2024 | 11:15 AM
djantlive's Avatar
Plugs are due every 50-60k mi. Most other items are wear and tear. Confirm if they are needed and get them done if needed
Old Dec 13, 2024 | 12:48 PM
Texas E63's Avatar
Built 2008 G55 & one big 80 Series LandCruiser !
I don't see where you are located - but someone likely can advise on a good Indy once you share that .... a few of these like the tires are high, others likely are sticky traps that will escalate ( rotors needed w/ pads - or new sensors or.......)
My stealership sees my G for oilchanges only or things that I don't mind paying a premium on due to part availability or timing....
E
Old Dec 14, 2024 | 09:59 AM
streborx's Avatar
Top Answer: 1
G550
Benzshops.com -- just enter your zip code.
Old Feb 17, 2025 | 02:03 PM
prospect25's Avatar
^this. Lots of Indy shops and some of this you could do yourself, like the headlight bulb
