Looking for a G63 engine
Old May 21, 2025 | 11:00 PM
bhamcarnut's Avatar
AMG GTs, G550, CLK430, Audi A3 avant, 78 Bronco
I am looking for a low mile M157 engine for a 2017 G63. Any ideas on the best place to find one? There are very few out there, that I have found. Even on scarce on eBay. Thanks in advance!!
Old May 23, 2025 | 12:26 AM
95_993's Avatar
G63
Can you share what failed?
Old May 23, 2025 | 12:12 PM
bhamcarnut's Avatar
Absolutely! I own a shop and we have someone that had just purchased it from a mom and pop dealership out of state. On her way home, it seized while driving. After inspection, the motor was found to have a lot of metal in it and it had cylinder scoring. I would guess at some point the oil was not changed as it should have been or it got real low. The owner is so sweet and we are trying to help her out. I’m a big Mercedes enthusiast as well so that’s why I wanted to see if any of the forum had some prospects. We might have found one with low miles. Keeping my fingers crossed.
Old May 23, 2025 | 04:25 PM
95_993's Avatar
G63
Thanks for sharing.
I was suspecting you might say bore scoring. I've been wondering if the available oil pressure solenoid that lowers the oil pressure at low loads has anything to do with the bore scoring on m157s.
Wishing you the best on the project. Please do a couple of posts as you go through the project.
Old May 23, 2025 | 07:48 PM
bhamcarnut's Avatar
Thanks for sharing.
Very good point. I had a 16 GL63 that ended up blowing the motor many years ago. It looked like it was starving for oil by the discoloration on areas of the rod caps.
I will make sure to add pictures and keep you posted on the progress!
