Launch OBD Scanner - Adventures in LKA Disabling
Diagnostics
There was not any option I could find that was an effective LKA kill switch, but there are a couple options on this same Launch menu, located at entries 010 and 011 on the Variant Coding screen shown below. "LDP Break Intervention Enable" (should be "brake") has two options, Enable and Disable. "ALDW Warning Mode" has three options, Vibration Motor, EPS, and Sound Warning.
Disabling the LDP brake function and setting ALDW Warning Mode to "sound warning" (rather than EPS - electronic power steering) SHOULD render Lane Keeping Assist to nothing more than an audible warning, and eliminate the harsh braking and steering correction effects.
I successfully coded these two variants to "Disable" and "Sound Warning", but because I installed a hack on my LKA switch module that simulates pressing the button and thereby disabling LKA every time I start my truck, I have no way of testing this code change (disabling my hack involves several hours of work). Is there anyone reading this who has a Launch scanner and who is sufficiently annoyed with LKA to do this coding change and see if these coding variants do disable the most annoying aspects of LKA? Please contact me if you're willing to do this and need further information.
Diagnostics
I would prefer to have it active, but only with a vibration or noise. Wondering if the first step should be left to “enable”?
I now have lka via steering wheel vibrations only. No messages on startup since it is still active. It’s nice not having a truck that doesn’t try to wreck you when crossing the line. 👍
So what we know is this: with LDP_Break_Intervention_ DISABLED, LKA does not work, but you receive a message upon startup that it isn't working and you have to hight the "okay" button.
This is the message when it is fully disabled.
Not wanting the message on startup, I went back in and enabled LDP_Break_Intervention_. I then set ALDW_Warning_Mode to Vibration Motor.
Upon testing, that seemed to work. No message at startup and during several tests, all I noticed was the steering wheel vibrating when crossing the line.
HOWEVER, LKA seems to have come back! Very weird. Just a few moments ago, I had one instance where it applied the brake!
Rerunning the scanner, I found several errors that seemed related. I have set it back to LDP_Break_Intervention_ DISABLED.
I'm wondering if something in the following pictures may be useful in turning off the warning message that it is inoperative?
https://renntechmercedes.com/index.p...rom-ldm-detail
