Black lower brush guard in black, does the finish hold well?
Just was trying to decide on color options for my 22 G63. I may go with the stainless or chromed front lower brush guard or the black. Have any of you with the black brush guard had good luck with the finish not chipping and scratching easy? I wasn't sure if it is a paint or if it is indeed a stainless brush guard that is chemically blackened.
I have a black brush guard on mine. Driven the car for two winters. Held up pretty well minus a few rock chips but nothing powder coating won’t fix. It is painted obsidian black metallic from the factory.
Look into getting it covered in Xpel if you’re concerned about scratches and chips.
Hope that helps.
Hope that helps.
Jagdpanzer (05-31-2021)
Hope that helps.
Hope that helps.
ustaadG (05-31-2021)
Jagdpanzer (06-01-2021)
The black version is powder-coated, a much more durable finishing method than paint. It holds up well, doesn't peel off or blister on its own, but a rock can ding it just like any other surface finish. My enthusiasm for the G63's "cow-catcher" is low - I think it looks like it belongs on an amusement park bumper car, and is one reason I opted for an ordinary G550.
Chrome is (I believe) an electroplating process, while powder coating is an electrostatic process. In powder coating, an electrically charged pigmented powder concoction is sprayed onto the metal that has an opposite electric charge, creating a molecular bond, and then it's baked at a high temperature to create the finish. I haven't seen the silver finish, but powder coating can produce every color and effect imaginable (and even some that aren't!). Doubtful that it's stainless steel as SS prices have gone through the ceiling. Even a simple SS fastener now lists for several times that of an ordinary zinc plated steel fastener.
When I decided on going back to the G, I had to modify a cart and build something for material support. (:
The dealer is telling you that MB black powder coats stainless steel? That's like having your Olympic gold medal bronzed!
Update: Here you go, painted stainless steel!
https://mercteil.com/amg-g-63-black-...retrofit-Ped20
I don't know what coatings they do. I just asked them if the silver bumper was a hard chrome or stainless. I can tell you with high grade stainless rifle barrels, they are sometimes coated over with black and are stainless underneath. By either a chemical process or another epoxy based product. That would give the buyer another color option I suppose with the push guard. They color yellow gold by using rhodium as well, or mix metals with yellow gold to get white gold, which looks more silver. In the end that would then that would take you from an Olympic gold to a silver (:
Got out my drill to core sample my G550's bar, but the battery was dead. So I used a magnet and found that the bar is strongly magnetic, and conclude the lowly G550's bar is ordinary steel. Cheaper grades of stainless steel are mildly magnetic, but your SubZero will never hold a fridge magnet. SS is heavier than ordinary steel, and with weight reduction emphasis to game EPA numbers, SS seems an odd choice for a painted bar.
