G Class (W465/W463A) W463 Produced 2019-2024: G550, G63 AMG W465 Produced 2025-
Need help!! 2020 G63, W463A, Bouncy Lorinser springs
Old Aug 11, 2021 | 12:54 AM
alaverdy's Avatar
W463A G63 AMG
Ok guys its my first time I ever lowered any of my cars, after installing Lorinser lowering springs on my 2020 G63 i kinda feel more bouncing even on sport+ suspension mode, i did twice alligment checked my tires psi and corrected, still feeling road roughness with bouncing by inch, first i thought im kinda paranoid, but then i took my other car 2018 First Edition E63S on same rough freeway road with sport+ suspension and totally different feeling, no bouncing just a rough road, any suggestions would appreciate it
Old Aug 11, 2021 | 09:57 AM
streborx's Avatar
Top Answer: 1
G550
What size tire/wheei do you have mounted?
Old Aug 11, 2021 | 10:16 AM
alaverdy's Avatar
W463A G63 AMG
its original 22 wheels on 305/40/22
Old Aug 11, 2021 | 10:51 AM
streborx's Avatar
Top Answer: 1
G550
IMO, this is the problem. Lowering springs are stiffer and combined with the short sidewall height of this tire on a 22" wheel, you're in for rough ride. If you know someone with a compatible set of 20" wheels, you could mount them and take a test drive to confirm this.
Old Aug 11, 2021 | 01:14 PM
alaverdy's Avatar
W463A G63 AMG
those tires been on prior installing spring, do you think if i switch to brabus lowering kit gonna have same problem?
Old Aug 11, 2021 | 02:36 PM
windtendo's Avatar
M5
Has it gotten worse? In your other post showing the before and after pics, you praise the ride and handling. I'm confused.
Old Aug 11, 2021 | 02:45 PM
alaverdy's Avatar
W463A G63 AMG
so first i went one size bigger on tires before installing speings it was perfectly fine normal as original tire size, but when I installed springs i got stiffer and bouncy
Old Aug 11, 2021 | 05:31 PM
streborx's Avatar
Top Answer: 1
G550
It seems unlikely one brand will perform differently than another when both have the same limitation of less vertical travel for absorbing impacts.
