3mo Out of Warranty = 15k Wiring Harness Repair!
https://www.nhtsa.gov/vehicle/2020/M...Communications
Can search whatever year your vehicle fits. Keep us posted on what MB says!
help us understand your situation. How many mile on the vehicle? Are you the original owner? Is your G stored in a garage or outside? What state/region are you located? Why is the wiring harness faulty, and was it caused by a rodent chewing the wire? Did you get a second opinion from another dealer or independent mechanic? How can others avoid this problem?
MB needs to get their sh*t together.
MB told me on that they would not cover a dime of it. Even though it's caused by an emissions component (oil vapor separators get clogged, blows out rear main) , it's one of 2-3 emissions parts NOT covered by the 8yr 80k emissions warranty.....
Good luck to the OP, I hope they do the right thing. They told me to F off in that scenario, and it was an even cheaper repair. My warranty had been expired for about 3 months also, and issue started at about 33k miles +/-
*time is money.
That way it's at least in the system BEFORE the warranty is up, youll have a better chance of a good will repair at that stage.
My dealer told me once the transmission is dropped to look at the RMS, the way the RMS is leaking will tell MB wether it's caused by the oil separators, or something else. Apparently the pressure either "sucks" the RMS in, or blows it out in a certain way that is a tell tale sign. I dont recall what he said exactly, but it's something like that.
The fact that there is internal communication with in MB that actually points to there clearly being an oil separator issue that causes a very specific type of RMS failure tells me they know exactly whats going on, they just refuse to step up to the plate. And like my dealer's smart *** (PENSKE MB NORTH SCOTTSDALE) told me, " ya I look at the forums too, that stuff is all anecdotal, we use real metrics to figure out diagnosis, blah blah blah" ... LOL. when I first dropped it off I said "already diagnosed for you, rear main seal is leaking, due to O.V.S." ... followed by him saying " how do you know that? that would be VERY odd, we haven't seen ANY RMS failures, and certainly no knowledge of OVS issues causing RMS leak"..... apparently they had "never seen it before".... ALL Lies... because 2 other dealers, and an independent MB shop knew all about it, and said it's VERY common on certain years of the 4.0L TT V8, same motor in G63, E63, AMG GT 63, etc..... Then the service manager at penske told me separately that it is indeed known issue, and the service advisor didnt have a clue. SO if youre reading this N. Scottsdale MB, we all know, and it's NOT anecdotal bud. LOL!!
The E63 RMS threads on this site have evolved to the notion that replacing the vapor separators as regular maintenance items is the only identified remedy. I would do this approx 40k miles, and not less than 60k miles.
The job is time consuming depending on the vehicle platform because the intercooler and induction details are different per model. Maybe on the G it would be less difficult because there is more underhood space to work with. C63 intercoolers are stacked in front of the vapor separators and behind the radiator so it’s a time consuming, but not rocket science, job.
Parts cost for this job does not seem too egregious.
Expensive repair at the dealer, to say the least. Less expensive at an Indy, and affordable DIY. I would start the job on a Friday night and finish up with the Italian tuneup Sunday afternoon.
I was basically mentioning to have the RMS checked for fun, and basically indicate there was RMS leak, or oil leak. Get a record of you mentioning an issue that will be tied to that dealer and VIN number. Keep the paper work, and records for it. For when the time comes that the RMS blows out, you can at least say "hey I had this looked at and it had an issue a year ago, you did nothing, now its a bigger issue, now its on you" may or may not work, but all you can really do other than pay 5-6000.00 for OVS every 2-3 years.
The parts for OVS and RMS are probably less than 500.00 total.
I told them NO, to the OVS replacement... Why? Because MB, and dealer said OVS failure is "purely anecdotal" remember ? LOL....
Soooo, when the NEW RMS blows out again, that repair IS actually under warranty now....
Since MB requires franchise dealers to offer a 2 year, unlimited mile warranty on their repairs...
So the RMS leaks again in 2 years? 'Ill be swiftly bringing it into the dealer for a free replacement... LOL. When they say," well you declined replacement of the OVS", ill say... "nope, anecdotal buddy, you couldn't guarantee that was the issue and wouldn't cover it under warranty back then, its not the OVS now either, was improper install, or faulty RMS seal... After all I cant imagine a REAR MAIN SEAL blowing out, simply due to some 200.00 emissions item right? that makes no sense! Must be a defective RMS, or improper install... " LMAO...
Yes the oil vapor separators (2x) are I think 150-200.00 each, and the RMS seal itself is about the same I believe. ITs all labor.... Some recommend dropping the entire engine to do the OVS, but at the very least both intercoolers need to come off, and a bunch of other parts in the way to access them, as well as a lot of fluids having to be changed and drained. The RMS the transmission def comes off to access that, at the very least.
Details of the procedure are quite different between W213, W205, W463, C190/C192 and others, because of intake duct and intercooler arrangement.
So the takeaway for us G owners is to replace the vapor separators preventatively every 3 years or so....?
