OBD-II Reader?
4 years and honestly ZERO issues with my 2019 G550. And one month after the warranty ends, the check engine light is on! Drives perfectly fine, but I would like to read the code.
Researching OBD-II reader market — what a hot mess! Fakes, model #s that make no sense (Autel 806 Pro is the same as the 808 Pro?). And very mixed reviews…
Not sure what to buy.
Who uses one and which model is recommended?
I bought a Topdon AD600 -- about $240 on Amazon. Reads/resets codes and sends a printed report, connects to wi-fi for updates (no PC connection needed). Topdon covers almost all car makes and isn't an annual subscription device. Topdon makes a full line of scanners -- however much you want to spend. Their product catalog at https://www.topdon.us/pages/topdon-catalog might help in choosing what you need. Topdon seems to be among the better quality scanners IMO.
When my battery died last year, it set off a chain reaction of error codes. After replacing the battery, it took about 3 reset iterations to clear them all, but the AD600 accomplished the task.
There are a couple brands that make MB specific scanners -- iCarsoft is one, but I know nothing about it.
Worked fine and confirmed it was a bad thermostat which was covered under warranty. Felt good to be able to go into the dealership letting them know the likely problem.
A number of codes came up, I was able to clear most but two that remained are:
Motor Electronics(ME)
• P240700 - The pump in the diagnostic module of the evaporative emission control system has a sporadic malfunction.
PTCU-Control Unit “Powertrain”
• U02A987 - Communication with coolant pump 1 of the charge air cooler has a malfunction. The message is missing.
• U02A902 - Communication with coolant pump 1 of the charge air cooler has a malfunction. There is a general signal fault.
Not concerned about the first one, but the second may be, although it seems like it’s a signal fault. And the Cooltant temp is Normal.
I was not expecting issues 1 month after the warranty ended, after having ZERO mechanical issues in the first 4 years and 35,000 miles.
Thanks for sharing the diagnostic codes. I assume you've had the last recall 23V097 (the one dealing with the possible wire harness chafing) performed, although it mentioned systems other than the charge air cooler possibly being affected. If not, maybe there's a comms cable in the same harness (?).
I run a diagnostic test every 4-6 weeks (even though no CEL triggers) just to see if anything unusual is going on. I have received unexpected error messages that seem unusual (and absent a CEL), such as "The switch 'brake light' has a malfunction. The signal comparison is faulty". I clear the codes, re-run the diagnostic scan, and then re-run it again after driving the car. When the codes don't reappear, I write them off as errors themselves. Did you try driving the car a short distance and then try again clearing the codes? My dead battery experience seemed to indicate error codes cascade, and once some codes get cleared, other codes can be cleared, but driving the car in between might be necessary so that all systems are activated and normalized. If the codes and CEL remain, I guess it's a trip to the dealer.
I guess if someone isn’t willing to do the repair themselves it is kind of worthless, but if you are semi-handy, their great.
