2021 G63 Check Engine Light
This sort of thing isnt all that uncommon, and thats for any car, not just MB, and not just G63. Sensors break, or have issues, or settings, or need to be recalibrated.
But so you know, asking if we've experienced a control module replacement and how long it should take is equivalent to asking your family how long surgery would take your doctor mentioned. "surgery for what?"..... " you know SURGERY! so I can get healed" .... "well we didnt even know you were sick, or what your symptoms are, or what the issue is, what is being operated on?" LOL Kinda need more to offer any information.
But with that said, random check engine lights aren't uncommon for any car, and usually aren't something that should cause a big concern as long as its not something where the car is put into limp mode, or car wont start etc. It's likely something minor like a sensor needing to be replaced, or calibrated. And 7-10 days isn't out of the norm especially if its an uncommon sensor and they need to order it or its on back order etc.
Now if it's a CEL and dumping blue smoke out of the back, and wont go above 3000 RPM, may have a bigger issue on your hands. But the fact that it's 100% drivable would usually indicate it's a minor sensor, or minor item having to do with the ECU data etc.
QUOTE=EJKaufman;8921207]Brought in my truck to the dealer as the check engine light was staying on despite the truck driving normal. This was on Tuesday morning of this week. Didn't really hear anything for 3 days so I contacted the dealer to see what the issue is and today they told me that they had to order a control module to fix the check engine light. They said it needs to be replaced. Has anyone had any experience with this? Apparently I won't have my truck back for a week to a week and a half in total, since I dropped it off on 2/6. The earliest the part should be at the dealer's is 2/13 or 2/14 and I don't know how long it takes to replace once the part arrives. Annoying![/QUOTE]
1. The coolant thermostat had to be replaced.
2. Had to replace the air filter for activated charcoal canister.
I finally just got my truck back today after 15 days at the dealer!! Thankfully it was all covered by the 4 year factory warranty 🙏🏻 Here is what the write up said was the problem and I’ll list all the parts used below the write up:
41214 ELECTROHYDRAULIC VALVE BODY ASSEMBLY INTERNAL MALFUNCTION IT WAS VERIFIED THAT THE CHECK ENGINE LIGHT IS ON. SDS CONNECTED WITH BATTERY CHARGER AND FAULT CODE FOUND P07B700. AS PER GUIDED TEST, CHECK OIL LEVEL NECESSARY. OIL LEVEL CHECK PERFORMED AND OK. IPR TOOL PERFORMED AND STATES TO REPLACE VALVEBODY ASSEMBLY WITH ELECTROHYDRAULIC CONTROL UNIT. VEHICLE SET ON LIFT AND TRANSMISSION OIL AND PAN REMOVED. VALVEBODY ASSEMBLY REMOVED AND REPLACED. INITIAL STARTUP PERFORMED. STANDSTILL ADAPTATION AND VALVE FLUSHING PERFORMED. OIL LEVEL CHECK PERFORMED AND FAILED. VALVE BODY REMOVED FROM VEHICLE AGAIN AND INSPECTED. PRESSURE HOSE MISSING FROM REFURBISHED VALVEBODY. TRANSFERRED FROM OLD VALVE BODY TO NEW. INITIAL STARTUP PERFORMED AND PASSED WITH OIL LEVEL CHECK PERFORMED AGAIN WITH STANDSTILL ADAPTATION PERFORMED.
Part Number
725-270-55-09-87
Labor Type: W Part Description
Qty List
REMAN CTRR. 1 UNIT,
ELECTROHYD.
725-271-21-01 OVERFLOW PIPE 1
725-271-61-00 GUIDE TUBE 1
725-271-53-00-64 ELASTOMER- 1 MOLDED SEAL
002-990-95-03 SCREW W RND. 10 HEXAL. HEAD
004-990-75-12 SCREW W 14 COLLAR A DRIVE
002-989-06-03-12 TRANSMISSION 9 FLUID
725-270-31-14 OIL PAN 1
725-270-55-09-87 CORE RETURN -1
725-277-24-02 OIL GUIDE PIPE 0
725-277-68-00 OIL GUIDE PIPE 1
725-277-09-00 OIL GUIDE PIPE 1
002-989-06-03-12 TRANSMISSION 3 FLUID
*Update* received the answer from my service advisor:
Good morning. No worries. The only part refurbished is the casing of the control unit /shell the rest is new.
Hopefully whatever the issue is this time doesn't take as long to fix!!!! Truck is still under the 4 year/50k mile manufacturer warranty.
