G Class (W465/W463A) W463 Produced 2019-2024: G550, G63 AMG W465 Produced 2025-
G63 fitting 20” A/T Tires
Old May 30, 2024 | 10:06 AM
Seanday's Avatar
G63
Hi guys.
Currently running the Brabus WideStar Kit but want to change from the sporty look to a more rugged look by changing wheels.
Have decided to go with 20” to clear the brakes
Has anyone tried the following tires and have pictures
285-50-20” = Correct size but dont know if it looks good or not.
285 -55-20” = Have seen photos looks ok but dont know if rubbing issues
305-50-20” = Have seen on Anrky Website / looks good but i think it rubs as saw some comments on website.
305-55-20” = Have seen on Anrky Website / Looks very good but the car seems to have brabus 2” lifting kit i doubt it will fit.
Anyone have any comments or photos. I believe my offset may be different due to wide body kit.
Thank you guys in advance for any input
Old May 31, 2024 | 01:02 AM
ustaadG's Avatar
My winters are 285/50r20. They look kind of small.
I would go 285/55r20 at a minimum.
305/50r20 will definitely rub as it is larger than my summers which are 305/40r20 and they rub.
I’ve seen 285/55r20 on instagram and they look good. Here’s the guy’s insta, https://www.instagram.com/hiroaki.71...ExeHB2eTVrMA==
Old May 31, 2024 | 11:40 AM
Chedman13's Avatar
2014 Mercedes-Benz GL63 AMG
I went through this and after research, 275/55/20 is the largest tire you can put on without any modifications and no rubbing at full articulation of the suspension.
I believe 285/55/20 will fit with slight rub at full turn, but nothing concerning - but at full suspension articulation, there is rubbing - posted from another member on this forum.
So I went with 275/55/20 for off-road and winter use on Brabus wheels. 275/55/20 also has a better selection of tires, and Falken Wildpeak are my favorite as they are winter snowflake rated, an all-season tire and all-terrain tire.
The rear are 23" Brabus wheels on 305/35/23 tires.
275/55/20 = 31.9" diameter, 10.8" wide
305/35/23 = 31.4" diameter, 12" wide
285/55/20 = 32.3" diameter, 11.2" wide
