24 G63 Tricke charger
pakoris (06-17-2024)
I use the access under the hood on the passenger side. There’s that red cover that slides to show a positive pole (like a metal blade), and I ground with the metal post on the side.
This is convenient because the battery is in the trunk under the cargo floor and requires removal of the metal clips to get access to.
No, the 12 volt port shuts off when you open the door. I have one from my GT3. You might be able to get alligator clips for that charger. I have a Yuassa maintainer that wasn’t expensive from Amazon.
Mercedes' battery/trickle charger is made by CTEK. Anyone that is made for your battery type is fine.
I personally use this one: https://smartercharger.com/collectio...oducts/pro25se
I'd recommend this:
https://smartercharger.com/collectio...omo-bundle-kit
or this:
https://smartercharger.com/collectio...oducts/cs-free
https://smartercharger.com/collectio...-chargers/?i=1
If you want the cheapest one that still works: https://no.co/genius1
I'd recommend this:
or this:
