G Class (W465/W463A) W463 Produced 2019-2024: G550, G63 AMG W465 Produced 2025-
2025 G63 Tire rubbing on All Terrain Tires
Old Apr 2, 2025 | 08:55 AM
Angus4x4's Avatar
Thank you so much! I have only seen Selenite grey in person once on a G wagon in loved it, so I appreciate seeing photos as I wait for my order. I also wanted subdued and not flashy, as I plan to build it up a bit with a roof rack, etc. This is my order:
  • Exterior: Selenite grey metallic
  • AMG Line package
  • Night Package Plus
  • Interior: Tartufo brown/black nappa leather, light brown zen wood trim, exclusive interior package, seat comfort package
  • Wheels: 20-inch AMG twin 5-spoke black
Originally Posted by streborx
Mine is Selenite over black Napa with the Night Package and multispoke wheels -- subdued, not flashy.
Old Apr 2, 2025 | 08:58 AM
Angus4x4's Avatar
Thank you so much! I have decided to go with the Toyo Open Country A/T 3s likely, but may consider the KO3s as I do more research.
Originally Posted by achatgrau
KO3 in 275/55/20s are coming this year. https://www.bfgoodrichtires.com/auto...errain-t-a-ko3 … they’ve got the release schedule through 2026 (though they haven’t called out specific launch phases with months like they did last year)
Old Apr 2, 2025 | 09:00 AM
Angus4x4's Avatar
I had wondered about that, but I think Streborx has a G550 and confirmed he made the switch with no rubbing at stock everything. Though, I think he had a different tire than I am planning.
The wheel well lining on the W465 seems to be different and I thought there were a couple other posts on here saying 275/55/20s aren’t as sure of a no rub fit depending on the tire.
Old Apr 2, 2025 | 09:03 AM
streborx's Avatar
Top Answer: 1
G550
There can be a difference in calculated versus actual tire diameter. The 275/60R20 calclates to 33" diameter, while the BFG spec lists 34.1" -- certainly enough to cause a problem in some cases. Some of this might be due to the KO3's 16/32" tread depth, compared to 12/32" on some less aggressive A/Ts (such as my Geolanders). The only way to know for sure is to ask someone who knows or have a tire shop trial fit a tire. But if I was doing serious off-roading, I'd focus first on fitting the smallest wheel size that clears the brake calipers, and then go with as much sidewall height that can clear with some margin to spare.
Old Apr 2, 2025 | 11:05 AM
Angus4x4's Avatar
Thank you so much for all your amazing advice! I plan to do only lighter off-roading with the G wagon, mostly easy forest and dirt roads around New England. So, I plan to keep my stock 20" wheels because it is mostly for on the road. I have my Land Cruiser 200 series for more serious off-road adventures, which has 18" wheels. These are the Toyo Open Country A/T 3's that I am likely going with, so hopefully there is no rubbing.
