Valentine 1 Radar Mount Solution
No thanks I prefer the classic style so I came up with a simple solution to mount the Valentine One on our glass since its so upright.
Just buy some small L shaped brackets and screws. Bend the brackets to the right angle with a few tests and some plyers and your all sorted. I shaved down the suction cups stem to get it into the smaller hole, so buy a few extra from V1 as if you mess with them too much it breaks the suction seal in the center, better to press them in gently than twisting them in.
I'm kidding😂
There is a US company that makes really nice mounts, just not sure how you hard wire it. I'm not a fan of fiddling with factory wiring. I learned my lesson with my 1979 CJ5 Renegade 😬
https://blendmount.com/?srsltid=AfmB...1tWlIabGjW18OI
Do you get the MB Connect error with Savvy? I tried using a brand new Savvy before I did the hardwire and it always gave the error at startup.
I bought a blend mount with an extra link. It fits great, tight up against the mirror. I can definitely tell it gets worse reception due to the glass but where it is at and the reception it gets is fine for around town. If I do a road trip I will pop it up on the visor temporarily.
The hardwire install isnt that hard, just time consuming and there is a great writeup about it on here. You just buy a plug fuse hardwire kit for the V1 and it plugs right in under the rear passenger seat into the 12v slot. The writeup (easy to find) has a full walkthrough. I prefer that over Savvy but then again the fuse tap way is the only way to get your radar up to the metallic free area.
I live in a hot climate and have 0 issues with using the cups, and the little L brackets I made took less than 30 min.. Hope that helps!
I've been playing around with locations for my Escort 360c, and I agree with you, the dash is where it looks best. I'm just concerned about velcro tape on the leather. I'd hate to damage it with whatever the sticky resin is..
If you want to place it on the dash, you could test a small piece of different velcro tapes on a piece of leather that is out of sight someplace. I bet there's some tape that will work without leaving a residue, or the residue can be easily removed with a bit of leather cleaner, etc. To me, the pros of placing the radar detector on the dash (or on top of the tweeter) outweigh the cons
