Power Loss
I dont know if the G has other issues or if its just probably the pump again. Any of you guys ran into this issue?
I cant imagine this is a heat soak issue. Do the G wagons heat soak that easy....?
When I first got the G55K it would throw codes under hard acceleration and go into a limp mode.
Turning the engine off and restarting would clear the fault.
There was a service bulletin T-B-07.08/61, March 6, 2006, that stated a software upgrade was required to resolve this issue.
Did the upgrade and no problems since.
