AAS DEFECTIVE AND AUXILLIARY BATTERY MALFUNCTION
Located in the passenger side footwell remove the plate under the glove box, pull back the carpet and then remove the back plate you will find the part.
replace the part put back together and you should be all good.
Tools required
T15
sockets
10mm long
8mm short
no diagnostics required.
Tools required
T15
sockets
10mm long
8mm short
Thank you for the info. I'll give it a try!
did anyone figure out wich wire the dealer replaced????
thanks
