G55 AMG (W463) Discuss the G55 AMG.
WATER LEAKING FROM REAR WINDOW WASHER
Old Nov 4, 2017 | 12:38 PM
parkertseng's Avatar
G63 wannabe
I NOTICED THAT THE THE WATER LEAK FROM REAR DOOR WINDOW WASHER PIPE LINE WHEN USING THE REAR WINDOW WASHER.
I OPENED THE REAL SIDE PILLAR PANEL AND FOUDN ONE OF THE CONNECTOR IS NOT CONNECTED.
CAN SOMEONE TELL ME WHAT HOSE SHOULD BE CONNECTED ON THE MISSING CONNECTER.
THE WATER KEPT COMING OUR FROM THIS SIDE WHERE THE CIRCLE IS.
THANKS
Old Nov 4, 2017 | 01:01 PM
ItalianJoe1's Avatar
2003 CL 600
If it came off, it must be in there somewhere.
As the rear washer only has one outlet, i'd assume that's a check valve that's failed and there's not supposed to be a hose there.
Old Nov 4, 2017 | 01:03 PM
G63 wannabe
I checked around the area, there was no extra hose left unconnected.
if the check valve has failed.
Does anyone know the parts number?
Old Nov 4, 2017 | 01:05 PM
2003 CL 600
The part # should be on the unit itself
