G55 AMG (W463) Discuss the G55 AMG.
2014 G63 Brake line upgrade option
Old Jun 2, 2022 | 11:45 AM
parkertseng's Avatar
G63 wannabe
Hi
I am looking to upgrade the brake line of my 2014 G63 to a stainless one.
However I can't any company make the kit for the car.
Only the ones for G500.
Does any know which brand make these available?
Or G63 is sharing the same brake line length from G500?
Old Jun 2, 2022 | 08:18 PM
SlappyMcSlapps's Avatar
G63 AMG
I will be getting these soon, but my '14 G63 is lifted.
https://jackwagonoverlanding.com/pro...cker-lines-set
Old Jun 6, 2022 | 07:24 PM
3WD's Avatar
3WD
SPONSOR
Car
Originally Posted by parkertseng
Hi
https://orc-shop.de/en/orc-off-road-center-gmbh/
Everyone uses ORC
Old Sep 7, 2022 | 06:00 AM
G63 wannabe
Does anyone know why there are two brake nose for my front wheel?
One is about 20cm and other one is about 50cm, they are connected together in series.
Really curious that why it is like this?
Can I replace it with a long steel brake hose?
Further more, I found total 8 hoses on the car.
3 are at middle on rear transfer case and 1 is at middle on front transfer case.
Shall I replace them as well since they looks like rubber hose.
The on at the front middle is with one side of banjo fitting.
Any suggestions?
Old May 8, 2023 | 02:51 AM
G212's Avatar
G55 (615hp), S63 (707hp)
Yep, I'd replace all. The one for the lockers looks the same as the other two in the back, the banjo fitting bolts to the hose. So, you'd need 3x equal length of those. Then 2x in the front (they are called inner and outer, or upper and lower), then 2x (lower) by the caliper in the rear. That makes a total of 9.
