2002 G55 Sunroof acting up
Subscribe
Feb 29, 2024 | 02:03 PM
Hello all,
I am looking forward to be part of this forum. Just recently bought a G55 and the sunroof is having some issues. Don't know if off tracks or the gear is missing some teeth or motor is on its last leg. If anyone has had the same problem before or if anyone knows what it is. I attached a link of the sunroof in action. If you know any places to get some used parts for the sunroof. Any input would be greatly appreciated.
Reply 0
Mar 10, 2024 | 09:24 PM
It’s not the motor, it’s the cable that’s in the driver side rear plastic panel that’s come loose from it sleeve. Remove the panel and you’ll see the cable there.
Reply 0
Mar 11, 2024 | 01:05 PM
Quote: It’s not the motor, it’s the cable that’s in the driver side rear plastic panel that’s come loose from it sleeve. Remove the panel and you’ll see the cable there.
That is amazing and probably save me lots of money. Has this happen to you before and fixed it yourself? Much appreciated
Reply 0
May 16, 2024 | 08:04 AM
mine is doing exactly the same, 2morow im going to try to fix it.
Reply 0
May 16, 2024 | 10:55 AM
Hi,
Here is a video I found on the fix. Looks easy to do.
Reply 0
Subscribe
Currently Active Users (1)
