General Discussion of Mercedes-Benz Classics Misc Discussion of the Classics, car spottings, museums etc.
1994 E320 Cab , bad idle
Old Nov 6, 2025 | 07:35 PM
ACM680's Avatar
I recently got this impeccable 1994 E320 Cabriolet, 2 owners and all records, 101K miles, CA owned all its life.
30K in receipt over that last 5 years, includes new head, and harnesses, hoses belts, new top, and associated hydraulics.
driven 3K miles over the last 6 years.
The second day I drove her , she drove great, good idle and power.
But I turned into my parking space, and the idle became very rough..
Drove her a little more, power is really nice, but idle was horrible.
I am a good mechanics on Mercedes, but this is a strange problem.
No vacuum leaks, tried another MAF, no change.
No check engine light either, coils and plugs are fine.
Could I have a VVT issue ?
Thanks.
Henri.
Old Nov 6, 2025 | 09:07 PM
MacVidMB-V8's Avatar
W209, W124
Check the cap & rotor. Frequently when my 400e ran rough I found moisture inside the distributor.
You said harness was done but double check anyway. Same with throttle controller.
Old Nov 6, 2025 | 11:15 PM
Alexie's Avatar
Clean your idle control valve. It's likely stuck from sitting. Also, check the throttle body electrical connector; it can come loose when turning.
Old Nov 8, 2025 | 06:55 PM
ACM680's Avatar
direct ignition, no cap or rotor . Harness is like new , throttle is a cable . Checked cam timing , indeed vvt was set to full advance , manually set it back to full retard.
Think the 320 never saw rpm over 4000 .
vvt actuator stuck .
She runs good now , no issues
