PML no power on that valve
Subscribe
Nov 17, 2025 | 09:35 AM
Hello i have a problem no power stering weel is bad or broken after inspection i found there is no power on socket after car running, when i share 12vdc to the valve all is working , so the case in in the instalation or fuses , can any one help to diagnose where can be the problem ?
Any diagrams or schematics where can i mabe found the issu apreciate....
Reply 0
Nov 17, 2025 | 09:48 PM
Check the fuses first. Look for the fuse that powers the power steering system in your main fuse box.
If the fuse is good, the problem is likely a broken wire or a faulty connection between the fuse box and the valve. Since you can make it work with an external 12v, the valve itself is fine. You need to trace the wiring back from the valve to find the break or bad connection.
Reply 0
Subscribe
Currently Active Users (1)
