Interface for cell phone
I found this info on a website:
- The Bluetooth Interface Module should be attached to the connector, located in the center armrest.
- Locate the Mercedes-Benz emblem on the front of the Bluetooth Interface Module and push down on it for 3 seconds. Blue lamps on the front of the module will begin to blink rapidly, then release.
- Pick up your wireless phone and set up your phone to pair to a Bluetooth device as per your wireless phone owner’s manual. During this process your phone will ask you for a code, enter 62872 on your PHONE’S keypad. Attention S and CL customers, 2 Bluetooth devices will appear as found on your wireless phone. Be sure to select MB Phone System.
- Your phone should give you a confirmation message the pairing is complete.
- Test phone by making a call through the vehicle.
- Turn off the engine, be sure to take the key with you, exit the vehicle.
If not, you have lots of wiring and electronic boxes to install first. Plus that connector. This will cost WAY more than $500.
The connector should be on the back wall of your console and look like the one in the photo (ignore arrows).
The latest version of the interface module is Mercedes part # B6 787 6131 and MSRP is indeed $493 for that part. It's $369.75 here: https://www.getmercedesparts.com/oem...des-parts.html
When entering part number at that website, omit the "B."
