Checking Oil Level on a 2013 C300 4Matic Sport
As a side note, in the owner’s manual for my wife’s 2009 BMW 328xi, it shows a dipstick to check engine oil. Well, it doesn’t have one. It’s done electronically.
As an engineer, I’m a bit disheartened at these simple mistakes, especially from two companies that pride themselves in “engineering”….
To get the actual amount of oil on mine I can enter a dyno mode. I turn the key to position 1 (not run or start), select the menu so you can see the mileage, and I push the reset button 3 times. This will bring up another menu that's available to scroll through and you can see a spot for the oil level in dashes. Turn the key to position 2 and it will show the actual liters.
Also there aren't dipsticks on mine but there should be 2 tubes that look like would be a dipstick--1 for oil and 1 for the transmission. Mine only has caps on it to seal it. The transmission one has a break away cap that needs replaced if you do it and on mine the oil has o-rings that I can pull the cap off to syphone the oil out.
That dipstick you see is for the oil and from what I see should be on the left side facing the engine. There is no transmission dipstick any longer and only has an overflow plug on the transmission itself.
You should still be able to get into some sort of dyno mode to maybe check more things out but not sure on the new model if its different. On the older W204 you would push the phone button and hold ok right after that for a minute still when the mileage is shown.
Here is info on the trans https://mbworld.org/forums/c-class-w...nsmission.html
And to get into the additional settings here's a video (the video is to reset the maintenance interval but there is vehicle data and dyno test also)
