General Mercedes Discussion Use this forum to discuss general Mercedes-Benz topics that are not specifically model related.
300CE-24 WHAT IS THIS?
Old Jan 8, 2015 | 03:10 PM
300CELOVER's Avatar
1996 SL500
Thumbs down 300CE-24 WHAT IS THIS?
Hey All,
Thanks VERY much for your help!
I have a 1990 300CE-24 and need to remove the harmonic balancer/ crankshaft pulley. Well, none of the drawings, pics, schematics, etc. that I can see anywhere online match my harmonic balancer on the rig. Please see attached photos.
Mine seems to be one-piece, whereas all the pics and schematics for this year and model show it be two with several bolts joining them together. I don't know how to remove it without accidentally moving the pulley and changing the timing. I'm sure it's tightened to 300+ lbs torque. Also, once the bolt is out, do I still need a puller of some type, or will it simply slide off?
My year is hard to find accurate pics, info., etc. online. I can always find info on the 1986-1989 as well as the newer 1992->, but not the 1990. Please HELP, thanks.
Attached Thumbnails 300CE-24 WHAT IS THIS?-dsc02162.jpg   300CE-24 WHAT IS THIS?-dsc02165.jpg   300CE-24 WHAT IS THIS?-dsc02167.jpg
Old Jan 13, 2015 | 08:12 PM
300CELOVER's Avatar
1996 SL500
Aw, c'mon guys! I know this is a STUPID question, as it's obviously the vibration damper. Still, why is there only ONE center bolt and will I need a puller? Or, because of the woodruff key will it simply slid off? THANKS THANKS THANKS!
P.S. I'm only asking these questions because all of the pics and info I get online shows a vibration damper with several bolts encircling the center bolt and mine doesn't look like it should, thanks again for any advice. M104.98
Old Jan 14, 2015 | 08:51 AM
mrbobby's Avatar
2003 S500 4Matic (SOLD) + 2004 S55 (SOLD) 2005 CLK 500 Cabriolet 2008 S 450
Sure looks like you're going to need a puller. Before pulling I suggest you mark the relationship of the balancer to the block and also to the crank shaft. You'll probably have to firmly tap the balancer with a hammer while applying pressure with the puller. Good luck.
