General Mercedes Discussion Use this forum to discuss general Mercedes-Benz topics that are not specifically model related.
Cylinder TDC not aligning with crankshaft pulley T/D markings. Help!!!!
Old Nov 12, 2016 | 12:05 PM
anthony9151's Avatar
2004 C230 Kompressor
Long story short, My my timing chain jumped quite a few teeth due to the camshaft teeth being worn out. So I removed the cylinder head to check for bent valves, and thank god they look ok.. But I will do a valve job since I already have everything apart.. Now my problem or lack of knowledge is that when the piston (Cylinder #1) is in the TDC position, the crankshaft pulley T/D mark is not aligned.. What are my missing here? see photos for reference.. Any feedback is appreciated because surely something is wrong, just can't figure out what it is... Thanks in advance..
Attached Thumbnails Cylinder TDC not aligning with crankshaft pulley T/D markings. Help!!!!-img_20161112_085341117.jpg   Cylinder TDC not aligning with crankshaft pulley T/D markings. Help!!!!-img_20161112_085359265.jpg
