General Mercedes Discussion Use this forum to discuss general Mercedes-Benz topics that are not specifically model related.
4 yr/40k service
Old Jul 11, 2017 | 11:34 AM
pjw1967's Avatar
2023 GLE3502W, 2024 GLC3002W, 1967 Pontiac GTO 4 sp (sold...sniff)
4 yr/40k service
We have a '14 ML350 CPO that's coming up for its 4/40. As a first time MB owner, I consulted the Maint Manual. I was surprised to see how much inspection is "REQUIRED".
It got me a bit worried about subsequent warranty work if this work isn't done by a dealer. I like going to the local dealer and I suppose they have to fund the loaners, free ice cream cones and car wash somehow. I was hoping to get away with a basic "A" service plus a brake fluid flush. Am I overthinking this?
(Pardon the cut and paste mishmash. The dots as you know denote which class gets what so not really germane to this discussion).
Required Service Work
C-Class
CLA-Class
CL-Class
CLS-Class
E-Class
GL-Class
GLK-Class
M-Class
SL-Class
SLK-Class
Engine – oil and filter change • • • • • • • • • •
Check catch, safety catch and hinges on
engine hood for proper operation
Check condition of poly-V-belt • • • • • • • • • •
Replace fuel filter (engine 642, 651) • • • •
Clean visible area of water deflector • • • • • • •
Check water drain in air/water duct for
obstructions; clean if soiled
Fill up DEF (engine 642, 651) • • • •
Reset maintenance service indicator in
instrument cluster
Check starter using STAR DIAGNOSIS tester
(E 400 HYBRID only)
Replace brake fluid • • • • • • • • • •
Replace combination filter and/or dust filter
(where applicable)
Check thickness of brake pads, front and
rear
Correct tire inflation pressure • • • • • • • • • •
Correct inflation pressure in spare tire
(where applicable)
Leakage – Major components: Check for
chafe marks, line routing, damaged
components. In the event of leakage,
determine cause and perform repair with
separate work order
Check DEF lines and components for leaks
and damage (engine 642, 651)
Visually inspect condition of front axle ball
joints, rubber boots
Visually inspect condition of rear axle ball
Visually inspect condition of driveshaft
flexible disks
Visually inspect condition of steering
mechanical components, rubber boots
Automatic transmission – oil and filter
change (engine 156, 157, 275)
Replace rear axle differential fluid (limited
slip differential only)
Replace air filter (except engine 275) • • • • • • • • • •
Check the following fluid levels; correct
if necessary
If there is a loss of fluid, determine cause and
perform repair with separate work order
Engine cooling system, antifreeze and
corrosion protection (engine 275, main
circuit)
Check coolant level • • • • • • • • • •
Brake system • • • • • • • • • •
Power steering (where applicable) • • • • •
Windshield washer system • • • • • • • • • •
Active Body Control (ABC) (if applicable) • •
Function check
Check parking brake (function test only) • • • • • • • • • •
Trailer hitch: Check condition and
functionality
