Little Help PLEASE
Subscribe
Apr 9, 2018 | 05:34 PM
I have a 2009 SL550 and I need to add Hydraulic Fluid for the convertible top, I bought the Hydraulic Fluid at the Mercedes dealership and I cant seem to find where or how to add the fluid, I did many searches on line and cant seem to find out where to add it, ??
any detailed help with possible pics would be GREAT !!!!!
ALSO ...... Just curious on this other problem, every morning I start my car it wont shift out of park for about 5 to 10 minutes of constantly moving the shift around, as the day goes on it has no problem shifting out of park , but once again , in the morning it does it again,
I do have a light on saying worn brake pads that I am replacing soon, does it have anything to do with that or is it something else >>?
Reply 0
Apr 11, 2018 | 11:11 AM
Quote: I have a 2009 SL550 and I need to add Hydraulic Fluid for the convertible top, I bought the Hydraulic Fluid at the Mercedes dealership and I cant seem to find where or how to add the fluid, I did many searches on line and cant seem to find out where to add it, ??
Here is a nice write up on replacing the fluid on SLK/SL. Process is a little different for each but not too much. Pump and resevoir should be under the trunk lining.
http://www.mercedesmedic.com/mercede...hooting-fixes/
As far as your transmission I'm not sure. Sounds like the problem goes away when things get warm? Hard to really say or diagnose without other symptoms. Did you check transmission fluid? Is it making an effort to shift? Nothing?
Can safely say it doesn't have anything to do with worn pads. Maybe take it to your local mechanic to get things figured out.
Reply 0
Subscribe
Currently Active Users (1)
