General Mercedes Discussion Use this forum to discuss general Mercedes-Benz topics that are not specifically model related.
Please help
Old Jul 12, 2020 | 08:25 AM
Klaadc's Avatar
S320
Please help
I have a 99 s320 that drove fine until I fueled up. I filled the tank and after the pump shut off I pumped it a few more times to get to a rounded number possibly topping it off. It drove fine from the gas station.. then after parking it, it wouldn't start at first.. it would just crank over. I eventually got it started after trying several times. It drove fine. Then I park it and now am unable to get it started. Just cranks over and now the dash reads "start error ". Battery is charged and good.
Old Jul 12, 2020 | 08:34 AM
turbo 6594's Avatar
ML63
How much gas did you have before refueling? In other words if you got “ bad” gas, what’s the percentage now in your tank?
you said it drove fine prior to refueling, are we correct to assume there were not error codes before or after the refuel?
Old Jul 12, 2020 | 02:45 PM
chassis's Avatar
2017 GLE350 4MATIC
Try opening the gas cap, then closing it again, with three clicks as you turn it to ensure tight/locked.
Old Jul 12, 2020 | 06:37 PM
Klaadc's Avatar
S320
I was close to be empty. If it were bad gas the percentage would be 101%. The gas cap isn't a mercedes gas cap. I left mine at gas station few months back and I'm using one that I found that fits. However I did try removing it and replacing it. The dash board is saying start error when I turn key over.
Old Jul 12, 2020 | 10:24 PM
chassis's Avatar
2017 GLE350 4MATIC
Buy a new Mercedes gas cap, install it, and continue with the diagnosis.
