General Mercedes Discussion Use this forum to discuss general Mercedes-Benz topics that are not specifically model related.
Multimeter check
Old Jan 28, 2022 | 02:15 PM
Marktee's Avatar
2012 C250 Turbo M271 EVO, 08 X3, 08 328i
Multimeter check
Anyone knows just by looking at the back of the multimeter whether this multimeter supposed to beeps when checking for continuity. I have Replaced the fuse On the left of the image And also has a new 9V battery. It works OK except for the Beeb Since I bought it
Old Jan 29, 2022 | 05:23 AM
ygmn's Avatar
2015 E400 Sedan
you have it in What looks like diODE test
Then all you have is Ohmeter for resistance which ca be used for continuity
Then only some brands will beep for 0 ohm ( dead short)
Old Feb 1, 2022 | 05:05 AM
Beer_Bandit's Avatar
CLS500
As stated above, you have it set to Diode mode in the picture.
Here's the manual for your multi-meter :
https://www.manualslib.com/manual/11...0b.html#manual
