General Mercedes Discussion Use this forum to discuss general Mercedes-Benz topics that are not specifically model related.
Illumination lights not coming on
Old Dec 19, 2023 | 07:22 AM
Chas0119's Avatar
E350 Bluetec
Hello, I have a 2012 e350 bluetec and I have a problem with the illumination lighting for the console (radio and door buttons). Also, the buttons on the dash doesn’t light up as well. At night I can’t see anything when I try to select mode for air flow or radio controls, because the buttons lighting not showing. I’ve checked fuses for illumination and ambient and they all seem to be good. Can someone point me in the direction I need to go for this? PS: yes I did go into the settings menu and made sure my backdrop lighting (dimmer) was up all the way and made sure lights were on.
Old Dec 19, 2023 | 09:08 AM
Vin_16's Avatar
C-Class
Hi Chas.. Maybe this will help.. It seems like you've taken some initial steps to troubleshoot the issue with the illumination lighting in your E350 Bluetec. Beyond checking the fuses and ensuring the settings are correct, here are a few additional steps you might consider:
Check for Wiring Issues: Examine the wiring and connectors related to the console and dash buttons. Look for any loose connections or damaged wiring that might be affecting the power supply to the backlighting.
Scan for Fault Codes: Sometimes, certain issues might not trigger dashboard warning lights but could still be logged in the vehicle's control modules. Using a diagnostic scanner, such as the Youcanic scanner, can help read fault codes from all the control modules in the vehicle, providing a better idea of any underlying electrical issues.
Professional Assistance: If you're unable to identify the problem after these checks, consider seeking help from a certified mechanic or an automotive electrician. They have the necessary expertise and tools to diagnose electrical problems accurately.
Since you've already performed some checks, considering these additional steps might help you further pinpoint the cause of the illumination problem in your vehicle.
Old Jul 3, 2024 | 02:20 PM
Chas0119's Avatar
E350 Bluetec
Thank You very much for your reply. I will do as mentioned and let you know the results. Again, TY.
Old Feb 15, 2025 | 12:56 PM
herlihy's Avatar
Did you find anything out? Mine is doing the same thing. thanks
Old Feb 18, 2025 | 01:10 AM
Olivia willson's Avatar
Creating a unique and stylish bio can make your profile stand out. Whether you're a cricket enthusiast, a photography lover, or someone passionate about farming, having a well-crafted bio adds a personal touch. If you're looking for inspiration, check out photographer instagram bio for some creative ideas. A good bio reflects your personality and interests, making your profile more engaging for others!
