General Mercedes Discussion Use this forum to discuss general Mercedes-Benz topics that are not specifically model related.
Fuel Injectors Cleaning 2012 E350
Old Dec 4, 2025 | 11:24 PM
RicoMarx's Avatar
Has 200k miles. Always used Chevron 91. Never had fuel injectors pro cleaned. Shops want $300. Can I try Techron Concentrate Plus first? Or?
Old Jan 8, 2026 | 07:54 PM
Ler's Avatar
Ler
1983 300TD, 1998 SL500 (sold), 2013 GL450
Any particular reason you want them cleaned now at 200k miles? I'm assuming you don't intend to pull your injectors to inspect and clean. If you're just talking about running chemicals through your fuel system, Techron is fine, or anything else that has PEA in it. I think Gumout Regane Complete Fuel System Cleaner is probably the best bang for the buck. Some people swear by Redline SL1. I tend to be a pragmatist- if you've been running Top Tier gas, and you're not noticing poor running or poor fuel economy, and you have no reason to suspect fuel dilution in your motor oil, your injectors are probably doing just fine.
