Musty Smell in GL450
I have a Gl450 with around 10,000 miles on it, and every time I start it I get a musty smell through the AC, almost like stagnant water. It usually goes away, but sometimes it comes back during regular driving. I'm aware that this can happen when recirculation is on, but I almost never have it on. Has anybody else experienced this problem? Any help would be nice!
Something along the lines of sulphur...
https://mbworld.org/forums/showthrea...hlight=sulphur
I hope those help, if not, try these.
https://mbworld.org/forums/showthrea...ighlight=musky
Other than that, I'm afraid I personally can't help you, but someone else might chime in.
Welcome to MBWorld.org btw, and update your profile!
2010 Range Rover S/C 2010 Land Rover LR4 HSE Lux Plus 2007 BMW R1200GS
It's mold starting to grow in the condensor.
There are smelly things you can spray into the air con intake system, but I have found the best method is to turn off the a/c compressor several minutes before you turn off the car and run the fan on a higher speed to dry out the condensor.
This seems to be a German car thing, as I have never had this happen with Japanese cars.
Hope this helps.
07 GL450
04 F250 crew cab
By the way, my 06 Range Rover which is designed by BMW does the same thing, but turning off the compressor a few minutes before turning off the engine, helps quite a bit.
Musty Smell in GL450's
Mercedes is having a real problem with this and we are experiencing it also. Our 2013 GL450 started smelling real bad through the vents at about one or two thousand miles. We were told quietly from the service person that they are having other complaints. We have friends come in the new GL and that is the first thing they comment about. Man we have looked in and around that car for anything that might cause the smell and the car is clean as a whistle inside. Mercedes quite frankly does not know how to fix it. I think our only choice is California Lemon Law.
My wife and I had a similar problem in her 2010 GL550. Stale/moldy odor. She ALWAYS leaves the vent controls on recirculate which I think might contribute to the problem.
At any rate, I replaced the two cabin air filters AND sprayed Lysol in the filter opening (after taking the old ones out, but prior to putting the new ones in). That took care of the problem almost immediately.
Good luck!
Good luck!
