Stainless rear bumper plate
Old 04-13-2007, 12:53 PM
  #76
Nevada Jack's Avatar
2011 E350 Cabriolet..White and Almond Mocha
Originally Posted by BeanCounter
NevadaJack,
I would be more than happy to help you out with the install. I actually went out and bought a Dremmel to cut off the clips. It makes a nice smooth cut and it cut down/minimized any sanding. Let me know.............
Jeff
Thanks Jeff...will keep you advised. Hopefully will have delivery 2nd week in May. I am in Summerlin...
Old 02-08-2008, 05:18 PM
  #77
ivrier's Avatar
GL 450 and X5
Just had mine installed following all of the instructions. It was a synch and took less than an hour. My rear has a completely different look, if you know what I mean.
thanks for the demo. Next upgrade will be the chrome indoor inserts.
Old 02-08-2008, 06:04 PM
  #78
oknish's Avatar
'07 GL 450, '02 S 80 T6
Post pics of your rear, if you know what I mean
Old 02-08-2008, 06:13 PM
  #79
cablvr's Avatar
'16 S550, '03 & '15 GMC Sierra 1500, '17 C300
IV,
I'm sure it's in this thread somewhere - what is the part # for the stainless rear bumper plate?
Old 02-08-2008, 06:34 PM
  #80
oknish's Avatar
Originally Posted by L8Apex
Just bought one today @ MBLN (local dealer)! Part #164-880-02-11
Retail $220 got it for $195.
Hope this helps!
Buy from MB Eugene since others have reported good deals from them.
Old 02-08-2008, 08:38 PM
  #81
cablvr's Avatar
Done!
Old 02-08-2008, 08:41 PM
  #82
LOL
Old 02-09-2008, 10:45 AM
  #83
ivrier's Avatar
GL 450 and X5
Here is the part number.
Part #164-880-02-11
Type in the number on the part number search.
http://www.trademotion.com/partlocat...?siteid=214269
I'll post pictures on my thread.
Old 02-09-2008, 06:16 PM
  #84
lkchris's Avatar
'07 GL320CDI, '10 CL550
Shows up nicely in the rear camera, BTW.
Old 02-10-2008, 02:03 AM
  #85
ivrier's Avatar
GL 450 and X5
Here is the finished product.
I also installed the chrome door inserts.
I cleansed the area with the alcohol pad provided, created a dog ear tag from the sticky tap, positioned the door insert and when it was to my liking, I pulled of the tape and secured it. It took less than 20 minutes to complete the whole task.
Enjoy the pictures.
Attached Thumbnails Stainless rear bumper plate-img_1712.jpg   Stainless rear bumper plate-img_1708.jpg   Stainless rear bumper plate-img_1710.jpg   Stainless rear bumper plate-img_1713.jpg
Old 02-10-2008, 11:16 AM
  #86
StevethePilot's Avatar
2004 RX330, 2008 Scion xB, 2001 Honda Insight Hybrid, 2010 Toyot Prius v ATP
I'm sorry but it's not finished until those fins are chrome.
Get back to me when you're actually done.
STP
PS
Old 02-10-2008, 11:40 AM
  #87
ivrier's Avatar
GL 450 and X5
You're definitely right about that. Anybody know what the part number of those fins are?
Old 02-10-2008, 12:00 PM
  #88
Formymercedes.com Jerry will take care of you.
http://www.formymercedes.com/mb_resu...Hood+Aerowings
Old 02-27-2008, 11:15 PM
  #89
JDT1's Avatar
'08 GL 320CDI
I finally decided I liked the chrome (stainless steel) bumper plate enough to buy one and replace the black plastic one with it. I hope to match up as many of the tabs with the existing holes in the bumper. I am aware from the many posts that some of the tabs or pins will have to be removed. I spoke with a contact at the local Mercedes body shop (very knowledgeable) who is willing to help and he suggests I use their eurothane adhesive instead of the 3M double sided tape. The adhesive is suppose to be the same or very similar to what is used to bond the windshield to the frame of the vehicle. He, as well as a co-worker seem to have more confidence in this instead of the tape.
Anyone here have any thoughts on this method of installation? BTW, I am in a hot climate (Texas) during many months of the summer, if that has a bearing on the method of choice. Thanks in advance for any input you can give.
Old 02-27-2008, 11:25 PM
  #90
scottybdiving's Avatar
2008 GL 320, 2007 Silverado LTZ C3500 Duramax Turbo Diesel
My only issue is that the curvature of the plate doesn't seem to exactly match the curvature of the bumper. Therefore, my plate is a little looser than I would like. It fits snugly on the right side but there is about a 1/8' gap on the left side. This seems to seperate the tape from the bumper somewhat. Although the bumper itself is somewhat flexible if you push on it, I was hoping for a much tighter fit.
I have come to the conclusion that the plate is merely cosmetic and serves no real purpose, other than for looks. I may try to re-install it with some clamps to hold it in place, when it warms up a little. The eurothane adhesive sounds like a viable choice to try.
Old 02-28-2008, 01:59 AM
  #91
JDT1's Avatar
'08 GL 320CDI
Thanks for the note, scotty. When you installed yours, did you leave as many tabs as possible, and only used tape for the curvature, or did you remove all tabs and pins, and load it up with tape? Also, the chrome plate is evidently standard on the 550. I wonder if the 550 bumper is the same as the ther models, or if it is slightly different, which I would doubt. If different, that may explain why it's not snug everywhere on your vehicle.
Old 02-28-2008, 07:33 AM
  #92
I left all the tabs in place, only removing the pins. I didn't want to try to drill holes in the bumper for the pins. The tabs all seemed to line up with the slots. I think the bumpers are the same and the fit is just due to manufacturing tolerances. You really wouldn't notice the 1/8" gap unless you knew to look for it.
Old 06-06-2008, 11:47 AM
  #93
bselph's Avatar
2008 GL320cdi
How do you remove the original black plastic bumper pad?
Old 06-06-2008, 11:53 PM
  #94
A large screwdriver, brut force, and a lot of resolve and trust in what you have read.
My only suggestion is that you don't place the adhesive the full length of the chrome strip. I think it cuased mine to not fit the curvature of the bumper as well. I am about to re-do mine, and I will only use the adhesive on the outside 1/2 of each side of the chrome strip, with nothing on the center portion.
Old 06-07-2008, 01:13 AM
  #95
JDT1's Avatar
'08 GL 320CDI
At one time, I thought I was going to use either the tape or a mastic product, but I decided against both. I got such a tight fit with the tabs fitting into square/rectangle holes that I decided to leave it alone. It sure doesn't feel like its going anywhere. I check it often, especially when I wash the vehicle, and feels really secure. Eventually, I may have to use the tape or mastic, but for now, I'm leaving it alone.
Old 06-07-2008, 03:32 PM
  #96
shoozlover's Avatar
2007 SL550 2008 GL550
Mine came with it already attached. Is this the same thing you guys are adding to yours?
Old 06-07-2008, 04:12 PM
  #97
JDT1's Avatar
'08 GL 320CDI
Yes, it's the same thing. It comes standard, only on the 550. The 450 and 320 CDI comes with a black (charcoal) plastic bumper plate that some of us are switching out in favor of the chrome.
Old 10-23-2008, 02:37 AM
  #98
DTMBENZ's Avatar
I JUST WENT AHEAD AND ORDERED ONE THRU MBEUGENE.............
Old 10-27-2008, 08:38 AM
  #99
kriskelsey2's Avatar
2008 GL450
Formymercedes.com has the chrome bumper plate for $195, which is reasonable. I have a Black 08 GL450 and I would love to have this chrome bumper plate on it. But I'm not the handiest of people and I would rather have a professional/body shop do it for me. I just moved here to the Dallas-Ft. Worth area recently, anybody know or can recommend a reliable body shop in the area that can install the bumper plate for me? Or can a MB dealer do it also?
Old 10-27-2008, 08:55 PM
  #100
robalo220's Avatar
2014 Black SLK 55 AMG, Black 2015 GL 550, 2011 Blue GLK 350
I have a GL 320. It has the black plastic piece on top of the bumper. Did yours have this or was nothing there? The crappy black plastic piece does nothing to protect the edge of the bumper. I scratched the edge of the bumper the second week.
I just dont know if I remove the plastic piece if there are holes under it. If so, will the metal piece cover them?
Quick Reply: Stainless rear bumper plate
