Accelerator Delay?
Old Apr 16, 2007 | 09:26 AM
EFant's Avatar
06 CLS55, 07 GL450, 07 GMC Yukon, 06 Pontiac Vibe
Accelerator Delay?
Has anyone experienced periodic delays when pressing the accelerator pedal? Sometimes I press the pedal and nothing. Then when pushing it farther, the vehicle surges forward. Now when it doesn't take off I just wait a sec. or so and then it goes.
Any similar experiences?
Old Apr 16, 2007 | 11:02 AM
carpersn's Avatar
2019 Volvo XC90 Magic/Amber, '95 E320 Cabriolet Midnight,'14 GL350 Lunar/Almond was '07 GL320CDI
SOunds like you have a transmission learning issue...i would try the reset process you can find by searching these forums (i don't exactly remember it)...I think it has something to do with holding the accelerator to the floor and turning the key to the accessory position twice or some such thing. good luck, as i have not experienced this.
Old Apr 16, 2007 | 05:27 PM
AsianML's Avatar
2007 E63
1. Turn key to #2 position (ON, but not ignition).
2. Depress accelerator all the way down through kickdown.
3. Hold there for 10-15 seconds.
4. Release accelerator pedal.
5. Turn key to #0 (OFF) position, but DO NOT take the key out.
6. Personally, I leave the key in there 2-3 minutes before taking it out just to be sure it works.
7. After waiting 1-4 minutes (or whatever is convienant, however I think at least 1 minute is good) take the key out.
Old Apr 16, 2007 | 06:31 PM
oknish's Avatar
'07 GL 450, '02 S 80 T6
What does this do?
Old Apr 16, 2007 | 06:41 PM
AsianML's Avatar
2007 E63
Originally Posted by oknish
What does this do?
Directions to the "ECU" reset. The tranny relearns your driving habits, but during that time, the transmission and engine respond wonderfully. You can do a search on "ecu reset" or something similar and you'll get a lot of results. I've tried it many times and I can feel a difference. I don't know if it's a psychological feeling though...
Old Apr 16, 2007 | 09:55 PM
boxboss's Avatar
It must be common to "learning" transmissions...
This was posted on the 7 series forum at Bimmerfest (thanks to DannyZBMW):
Has anyone tried this on their 2006/2007 5/6/7 Series:
Insert the Key to into the key fob (DON'T HOLD THE BRAKE).
Press the Start Button ONCE, just so the car electronics start and show the Engine light is on. (Again, Don't START the Engine).
Press and HOLD the GAS PEDAL all the way to the force down click on the gas pedal for 25 seconds.
After those 25 Seconds, proceed to Starting the Engine and drive your car.
Now, do you notice that the car responds better and shifts better, or is this just me????
The placebo effect must be a concern to MB as well as BMW owners!
Old Apr 16, 2007 | 10:20 PM
oknish's Avatar
Thanks, folks.
And, now to the garage...............
Old Apr 17, 2007 | 10:53 AM
EFant's Avatar
Good Info. I'm at work now and going to the parking lot right now to try the steps.
Old Apr 17, 2007 | 11:25 AM
EFant's Avatar
Thumbs up Thanks A Million!
Bingo!!! Feels like a new vehicle. I followed the aforementioned steps and it accelerates perfectly.
Thanks Guys,
Old Apr 17, 2007 | 05:47 PM
2thfixr's Avatar
Depends where I'm going.
There is one thing that we learned for sure from this thread. You drive like an old lady.
Old Apr 17, 2007 | 07:02 PM
AsianML's Avatar
2007 E63
Snap!! I forgot that you take your foot off the gas pedal after the counting of 10-15 seconds. Something like that.
Old Apr 17, 2007 | 08:01 PM
Danno4x4's Avatar
2007 GL320 CDI, 2001 TJ Rockcrawler, 2005 Scoobie STI
I did a search but there was nothing conclusive...
How would this reset procedure go for someone with the Keyless Go feature....
Can I assume that I would need to pop out the keyless go button and insert the key?
Old Apr 17, 2007 | 08:04 PM
AsianML's Avatar
2007 E63
I assume so!!
Old Apr 17, 2007 | 08:38 PM
oknish's Avatar
Press the Start/Stop button twice without pressing the brake pedal down. That is same as key being in II position.
Old Apr 17, 2007 | 09:14 PM
Danno4x4's Avatar
Thanks oknish... Your post was helpful.
The other? Just padding I guess.
Old Apr 18, 2007 | 01:57 PM
Taz0369's Avatar
Don't forget to tug your left ear three times and hop on your right foot twice
