The wait is over!
Old May 19, 2007 | 05:42 PM
  #51
boxboss's Avatar
Originally Posted by jpeardm
Looks great! I like OB also and it was a toss up for me between OB and Capri Blue with the Mac interior. Anxious to see the wheels on. Good luck!
I really like your Capri Blue as well. From your pics it appears a very dark blue. Good choice.
Originally Posted by carpersn
Great Lookin, Box...like the sills ALOT! As for the cruise stalk, it's been that way on MB's since late 70's early 80's...you'll get to thinking it's perfect.
Maybe not perfect, but I'm quickly becoming used to it.
Originally Posted by dcrna
Box, I was over at Mercedes of Memphis yesterday and talked to your SR. Congrats on the GL, looks good.
Tom sent me an email to that effect. Your wives work together, eh? Small world.
Old May 19, 2007 | 05:53 PM
  #52
boxboss's Avatar
Bumper plate
I put on the stainless bumper plate this afternoon. It was very easy! About 45 minutes, start to finish. I can only unpload 5 thumbs, so here's the odd one - a picture (we've probably all seen) of the black plastic one. Full details in the next post.
Old May 19, 2007 | 06:39 PM
  #53
boxboss's Avatar
Stainless bumper pad is on!
First, thanks to blittle for the hard part - the first to pull the black one off. It will come off exactly as he says. I pulled up on the front right corner and kept pulling until the first pin broke. I would have been very apprehensive at this point if it were not for blittle's post. The black one has 4 plastic pins that have thin metal nuts attached. The pins will break off easily. The black one also has "L" shapes that slide under the edges of holes in the bumper. As you work from right to left, pull back on the piece - this allows the L shapes to slide out from under the holes in the bumper. I broke 3 of the 4 pins, the 4th (last on the left) slid off like the L's. Picture 1 shows the OEM part half way up, the "L" shapes, and holes in the fiberglass bumper. Picture 2 shows the holes in the bumper when the OEM is removed.
The stainless part has 4 pins that need to be removed. These are not the same as the 4 pins previously discussed. The 4 pins are on the part that wraps over the back and down. There are no holes in the bumper for these. I clipped these off with wire cutters and filed/sanded them smooth - 10 minutes max for all 4. One of these pins is shown in picture 3 - with white paper underneath for clarity.
The stainless L's are a perfect match for the holes in the bumper for the OEM part. The stainless L's look different from the OEM L's, but function the same. They fit by friction - and tightly. I put a strip of 3M mounting tape along the downward facing edge as a precaution - but this probably isn't even necessary - the clips fit into the holes very tightly. Picture 4 shows the tape and stainless L's. Put your tape (if you decide to use it) as close to the bend as you can, without going into the bend. My tape could have been closer to the bend in the part, downward in the picture.
Remove the red backing from the tape (if you use it) and place the stainless L's into the holes in the bumper. Hold the piece firmly down against the bumper - you may want a helper. I bumped the downward facing piece forward with the heel of my hand, working left to right, to get the L's to slide forward under the bumper holes. This is a lot easier when you're doing it than it sounds. The L's slid into place and I'm good to go. Finished plate is the last picture. It was actually really easy. Of course, if you want to go 100% tape you can, but there's a lot more pins and L's to remove.
BTW, I was able to retrieve the broken off metal nuts by shining a flashlight into the holes (picture 2) and using a large bamboo skewer to insert into the nut and pull it up to the edge of the bumper hole and grab it. This is easier to do than write about. You can also gain access from underneath the bumper. Be sure to do it before you put on the stainless plate so you can see light shining through the holes. Good luck!
Attached Thumbnails The wait is over!-oeml.jpg   The wait is over!-holes.jpg   The wait is over!-pins.jpg   The wait is over!-tape_l.jpg   The wait is over!-done.jpg
Old May 19, 2007 | 10:30 PM
  #54
blittle's Avatar
2013 GL450 (traded for 2015 Escalade), 2012 Corvette, 2014 Ford Fusion, Previous: 2007 GL450, 2011
Great job Box.......! And.....great pics.! I'm glad you still had your stainless still intact and could make the appropriate mods to make it work! Hopefully others will benefit from our "pioneer work" because it's well worth it.......the stainless plate really adds that "touch of class" equal to the rest of the vehicle........I also was able to get out the two nuts that fell in the bumper.
Old May 19, 2007 | 11:58 PM
  #55
Stumblefoot's Avatar
'06 A6 & '08 GL550
Box -
Great post and love the pics! Thanks for taking the time to share your experience. It really is amazing how much better the chrome looks on the vehicle.
Looking forward to seeing the new wheels after you have them installed. Enjoy the cool weather while it lasts!
Old May 20, 2007 | 12:22 AM
  #56
oknish's Avatar
'07 GL 450, '02 S 80 T6
Great work, boss. You really showed MB who is the real boss. Plate looks swweeeet. More pics, please.
Old May 20, 2007 | 08:19 AM
  #57
Nevada Jack's Avatar
2011 E350 Cabriolet..White and Almond Mocha
Excellent tutorial box...and nice images. I am glad the holes match with the clips on the chrome piece but for the ones on the lip that there are no holes for. That is discouraging...I was hoping for a perfect fit. I will just have to see what the body shop offers to do and if they cannot (or don't want to) do the replacement then I will do what you did. Thanks for the details.
Old May 20, 2007 | 10:36 AM
  #58
GLDriver's Avatar
F150,GL450, G63, Aprilia Tuono, Honda Cbx
nice
Great work Boss.
OK . I am not selling my plate anymore. It is replacing the fugly plastic this afternoon !! Pictures to follow.
Old May 20, 2007 | 09:25 PM
  #59
boxboss's Avatar
Finally, the pictures
Thanks to oknish for the AMG pedal info, I like them a lot and to Brabus164 for getting me started on the Monoblock E's - I think they look great on an OB GL. I can't remember where I first heard of the PE running boards, but I'm glad I did.
Attached Thumbnails The wait is over!-brabus.jpg   The wait is over!-inside.jpg   The wait is over!-peboards.jpg   The wait is over!-pedals.jpg   The wait is over!-plate.jpg
Old May 20, 2007 | 09:35 PM
  #60
boxboss's Avatar
And more
Now for the GL...
Attached Thumbnails The wait is over!-9.jpg   The wait is over!-11.jpg   The wait is over!-18.jpg   The wait is over!-21.jpg   The wait is over!-22.jpg
Old May 20, 2007 | 09:44 PM
  #61
boxboss's Avatar
even more
more...
Attached Thumbnails The wait is over!-12.jpg   The wait is over!-16.jpg   The wait is over!-25.jpg   The wait is over!-32.jpg   The wait is over!-41.jpg
Old May 20, 2007 | 09:57 PM
  #62
boxboss's Avatar
Last ones
Five more for a couple of guys (you know who you are) that were so insistant!
Attached Thumbnails The wait is over!-28.jpg   The wait is over!-31.jpg   The wait is over!-26.jpg   The wait is over!-40.jpg   The wait is over!-29.jpg
Old May 20, 2007 | 10:19 PM
  #63
StevethePilot's Avatar
2004 RX330, 2008 Scion xB, 2001 Honda Insight Hybrid, 2010 Toyot Prius v ATP
Uhh ...
What're you saying, Boss?
By the way, maybe I missed it somewhere earlier in the thread, but where do you actually get the SS bumper plate? (Sounds like an old battleship.)
Old May 20, 2007 | 10:21 PM
  #64
Newbie_2_MB's Avatar
2014 GL 450
One other thing - who decided to put the cruise stalk above the turn signals??? This, IMO, is a major design flaw. I changed my cruise speed every time I changed lanes. Anyone else think this?
My husband hits it every time he drives the GL, but I don't have that problem. Maybe because my hands are smaller??
So glad you're happy with your GL. Great pics, too.
Old May 20, 2007 | 10:27 PM
  #65
boxboss's Avatar
1) Inside joke to NJ and oknish.
2) Get the bumper plate at your MB dealer - it is an EU OEM part. I have the part number at work and will post it tomorrow. List is ~$200 but my dealer matched MB of Eugene (Oregon) online price of ~$169.
Old May 20, 2007 | 10:52 PM
  #66
GLDriver's Avatar
wow
The black Truck of your is very beautiful. Great job on plate. Here are a few pcitures of my ugly white ..
Attached Thumbnails The wait is over!-img_2936.jpg   The wait is over!-img_2937.jpg   The wait is over!-img_2938.jpg   The wait is over!-img_2939.jpg   The wait is over!-img_2940.jpg
Old May 20, 2007 | 10:59 PM
  #67
boxboss's Avatar
Bah! There is NO ugly GL! If I had not have gotten a wild hair, I would have a white one, too. Did you do your bumper plate today?
Old May 20, 2007 | 11:05 PM
  #68
'06 A6 & '08 GL550
Box is the Man!
Amazing, incredible, phenomenal, outstanding, and awesome pics Box.
Right now, on my computer screen I've got the nearly identical shots you took of the 18's on Friday plastered right beside the new Pirelli 20's on Sunday. I'm like a kid in the candy store ready to make my pitch to Mom, er wife , on why the 20's are a necessity.
Enjoy the ride and thanks for posting pics of the new beast. BTW, I love your property... looks like an absolutely beautiful setting.
  #69
GLDriver's Avatar
No..
I agree
Couldn't do the plate. Had to take the kids down to Circus and I didn't have the tape. Will be doing this week for sure
Old May 20, 2007 | 11:14 PM
  #70
boxboss's Avatar
Thanks Stumblefoot, and everyone else, too. My other cars are bone stock and I decided to have some fun with this one. Now, get your argument down pat and make that pitch!
Old May 21, 2007 | 01:30 AM
  #71
oknish's Avatar
Car looks great, BB. Those wheels look AWESOME. I am guessing we are talking a triple coat of Zaino? How long did it take you? I am doing mine, again, on memorial day weekend. Should be fun
GLDriver - seriously, your White looks great also. I love the look of skid plates on white. I think they look better than on Black.
Old May 21, 2007 | 01:38 AM
  #72
oknish's Avatar
That's cause this one is a keeper and you know it.
Old May 21, 2007 | 06:23 AM
  #73
jpeardm's Avatar
13 SL550, 14 E63 Wagon, 15 S550, 11 M3, 08 F430 Spider, 12 ML350
Looks good Box! Those Pirelli's must handle very nice, are they useable in snow? The wheels fit the car really well. They don't look too bad to clean either. I have the 19" split spokes and they're a pain to get into the split area. We expect you to keep them sparkling at all times!
Old May 21, 2007 | 06:54 AM
  #74
AsianML's Avatar
2007 E63
Brabus is PERFECT for the GL.
Old May 21, 2007 | 08:18 AM
  #75
boxboss's Avatar
About 4 hours total. After washing, I had a significant number of water spots (hazard of black) and a little adhesive left from shipping tape. I applied Klasse AIO (All-In-One) to clean the spots and adhesive - AIO is a great product. Then a coat of Souveran carnauba wax. I've always thought carnauba is better on dark colors even though it is much less durable than Zaino.
