The wait is over!
If you decide to go with 20's, I would advise keeping your stock wheels (18 or 19) and using them with some good snow tires in the winter. The 20's are too wide for the winter.
The MonoE's are not difficult to wash, and I do plan on keeping them sparkling.
Love the new wheels
Do you notice any change in the ride from the stock 18's? I am getting the Appearance 19's and just wonder if the jump to 20's effects the ride at all.Your posts and GL's (of his "ugly" one) show why this SUV is such a hit. Beautiful but conservative lines and a sharp profile against the competition. Your extra wax skills on the OB will keep it shinning for many years to come.
Enjoy
Love the new wheels
Enjoy
BTW, a D70 makes the camera work easy.
I use a Canon 20D SLR and a nice variety of lenses that make good pictures pretty easy these days.
2) I'll see if I can find it online. It's not in the "Genuine Accessories" book for the GL, so my parts guy will have trouble finding it.
Thank you for the info!
Bumper plate: 164-880-02-11 $169.50
Had one parts guy tell me that to get Chrome bumper plate, I have to order the whole bumper. I can swear that I have read someone else say the same as well.
If you need to buy anything, buy from MB of Eugene online. And when you need the warranty work done go back to your dealer. Make sure to let the Service Manager know about this too and how they are losing your business.
This is growing tiresome. When I brought in my LX for work from someone backing in to the front quarter panel, Lexus not only gave me a loaner but filled the tank when I came back to check on something and it was empty. All in all, the same car (petrol) from Lexus costs less and has a longer warranty. Does anyone else see a growing worry here?
You can however order a Stainless one and install it. There was a write-up about how to do this with double sided tape.
I know oknish used L8Apex's method (and help) so he can better advise you on the 100% tape install.
Edit: Here's the link to L8Apex's instructions SS Plate Install
Thank you guys, very much!
Steve
Yup...........!
The stainless part has 4 pins that need to be removed. These are not the same as the 4 pins previously discussed. The 4 pins are on the part that wraps over the back and down. There are no holes in the bumper for these. I clipped these off with wire cutters and filed/sanded them smooth - 10 minutes max for all 4. One of these pins is shown in picture 3 - with white paper underneath for clarity.
The stainless L's are a perfect match for the holes in the bumper for the OEM part. The stainless L's look different from the OEM L's, but function the same. They fit by friction - and tightly. I put a strip of 3M mounting tape along the downward facing edge as a precaution - but this probably isn't even necessary - the clips fit into the holes very tightly. Picture 4 shows the tape and stainless L's. Put your tape (if you decide to use it) as close to the bend as you can, without going into the bend. My tape could have been closer to the bend in the part, downward in the picture.
Remove the red backing from the tape (if you use it) and place the stainless L's into the holes in the bumper. Hold the piece firmly down against the bumper - you may want a helper. I bumped the downward facing piece forward with the heel of my hand, working left to right, to get the L's to slide forward under the bumper holes. This is a lot easier when you're doing it than it sounds. The L's slid into place and I'm good to go. Finished plate is the last picture. It was actually really easy. Of course, if you want to go 100% tape you can, but there's a lot more pins and L's to remove.
BTW, I was able to retrieve the broken off metal nuts by shining a flashlight into the holes (picture 2) and using a large bamboo skewer to insert into the nut and pull it up to the edge of the bumper hole and grab it. This is easier to do than write about. You can also gain access from underneath the bumper. Be sure to do it before you put on the stainless plate so you can see light shining through the holes. Good luck!
