The end is near....
Old May 24, 2007 | 07:45 PM
oknish's Avatar
'07 GL 450, '02 S 80 T6
Originally Posted by Nevada Jack
I agree with your conclusion Jack. The test track for this new solution is the the interstates and the test drivers are the buyers. No thanks....
+1.
Be polite but firm , Jack.
Old May 25, 2007 | 02:10 PM
CHeeCH28's Avatar
AutoSaurus, when did you purchase your GL 320 CDI?
Old May 25, 2007 | 02:29 PM
AutoSaurus's Avatar
1997 E320 Sedan
See my signature.
Built 1/07
Purc 1/07
Old May 25, 2007 | 02:31 PM
AutoSaurus's Avatar
1997 E320 Sedan
MB rep left a message on my home answering machine. Said he would call back on Tues. No number to return the call. I guess they don't want to be bothered except on their time. Jerk.
Old May 25, 2007 | 03:14 PM
AutoSaurus's Avatar
1997 E320 Sedan
First photo is the Q2 hose which is detached
Second photo is the Q2, Level II hose after installed
Attached Thumbnails The end is near....-q2-level-i.jpg   The end is near....-q2-level-ii.jpg
Old May 25, 2007 | 03:49 PM
Nevada Jack's Avatar
2011 E350 Cabriolet..White and Almond Mocha
Jack's Pics
Thought this might make it easier to see the difference...thanks for the images Jack. Tight quarters and hopefully for all 320 users a good fix.
Old May 25, 2007 | 05:09 PM
  #32
petery's Avatar
Hmm... This looks similar to the twin turbo RX-7 I had back in '93. Mazda was never able to come up with a solution with the hose coming off. I don't know what the hose was for but wheneve it came lose, I would lose power. Only if I knew what I know now... Good luck with your buyback demand, it is a major safety issue in my opinion.
Old May 27, 2007 | 10:54 PM
  #33
EricM's Avatar
2014 ML350 BT, 2016 Jeep Wrangler Rubicon HR, 2012 GMC Sierra Denali HD Duramax
I haven't seen any posts about this problem for the ML320 CDI. Is there something different about the GL installation of this engine that causes the problem? I'm planning on ordering an 08 ML320 but would have second thoughts if this is a common problem.
Old May 28, 2007 | 10:05 AM
  #34
sprink49's Avatar
2004 S500
You are *** kidding me!!! A worm drive hose clamp? How about a threaded collar and nipple arrangement with Lock-Tite sealant? Big opportunity for the aftermarket.
Old May 31, 2007 | 05:03 AM
  #35
tjpdvm's Avatar
2012 GL 350, 2011 E 350, 2005 F-250
Any progress?
Old May 31, 2007 | 10:27 AM
  #36
AutoSaurus's Avatar
1997 E320 Sedan
Originally Posted by tjpdvm
Any progress?
Nope. Not a word. I listen to the message again and he said he would call back on Tuesday. On Wednesday morning I called MB and they said the notes in the computer say the same thing. The phone rep was a little confused too as to why he hadn't called back. I verified all my contacts too. They are correct. Afterwards, I called the phone number from the call ID and it happened to a direct line to his voicemail. I left a message.
As of this morning, still no call.
Old May 31, 2007 | 11:34 AM
  #37
AutoSaurus's Avatar
1997 E320 Sedan
letter
I am attaching a letter that will go out today.
Please comment. Thanks
File Type: pdf
Old May 31, 2007 | 01:13 PM
  #38
mbslk350's Avatar
2021 GLS450, 2015 E250BT 4Matic, 2007 GL320CDI, 2005 SLK350, 2001 SLK320
Sounds good. Firm but professional. No emotion, just the facts. You described the problem and said what you want them to do about it. And you copied the big guy in new Jersey. I would not change a word.
Edit: Just thought of one more thing. After you fax it, be sure to send another copy via certified mail with return receipt. It's a pain, but that's how you prove they received the letter.
Old May 31, 2007 | 01:42 PM
  #39
oknish's Avatar
Looks great, AS. Should be a model for future. Just one question - shouldn't you list who at the dealership will get this letter instead of just the dealer name?
Old May 31, 2007 | 02:25 PM
  #40
AutoSaurus's Avatar
1997 E320 Sedan
I'll have the name on the fax cover sheet. It will be the General Manager. He's expecting it too.
Old May 31, 2007 | 03:00 PM
  #41
oinick's Avatar
2007 GL 320 CDI, 2008 M5
This hose thing is getting scary. I am over 4000 miles with no trouble. March 21 build date. How can I tell what kind of hose I've got? I mean, how do I now if it's Q1 or Q2 or what? Going on a lot of road trips this summer and I will address this with the dealer at the free 5000 mile service.
Old May 31, 2007 | 03:06 PM
  #42
AutoSaurus's Avatar
1997 E320 Sedan
Look at this thread for photos and what the stamp looks like. I used a camera in macro mode to take a photo since the writing was on the side and I couldn't see it. Worked great.
I'd be interested to know which yours has too.
Old May 31, 2007 | 03:08 PM
  #43
Norris's Avatar
GL320 and C350 on order
With a January 18 build date, we talked to 3 dealers and not one of them said they have heard of a problem with the GL 320 CDI. Printed off this thread and others for them to read and not one of them say they have seen any problems. HMMMMM!?!? So if there is a problem it must not be something MB believes is not wide spread.
So I do not know what to think with 4500 miles we are still running strong.
Old May 31, 2007 | 03:27 PM
  #44
StevethePilot's Avatar
2004 RX330, 2008 Scion xB, 2001 Honda Insight Hybrid, 2010 Toyot Prius v ATP
The service manager at the dealer where I bought my GL stated to me that he had a bulletin regarding the hoses, though there's not a formal recall (yet). I believe there is a bulletin number available as well somewhere here? Suffice to say, if they have a service department then someone there knows there is a problem.
Old May 31, 2007 | 03:48 PM
  #45
AutoSaurus's Avatar
1997 E320 Sedan
I believe this is the one.
File Type: pdf
Old May 31, 2007 | 04:02 PM
  #46
tjpdvm's Avatar
Mine went out at 7500 miles. Build date was 1/07, and took delivery first part of March. Was repaired last week with Q2 hose. 900 miles on it without problem. Willing to put up with one more failure, as this is the best vehicle I have ever worked out of.
Old Jun 4, 2007 | 10:13 PM
  #47
AutoSaurus's Avatar
1997 E320 Sedan
Just an update....
Still not a word from MB since they received my letter on Friday 6/1 at 1032am.
My initial phone message from the regional rep promised a return call on Tues 5/29 but that still hasn't happened either.
I called today to the CS center. They hadn't a clue.
Old Jun 4, 2007 | 11:09 PM
  #48
AutoSaurus's Avatar
1997 E320 Sedan
I encourage everyone who has had this issue to please file a complaint with NHTSA. It only takes about 5 minutes.
I had to file this under GL450 since the 320CDI is not listed. I'll call to see if I can get this corrected.
NHTSA Complaint
