Interior Lighting question.....
Old Jun 3, 2007 | 08:05 AM
blittle's Avatar
2013 GL450 (traded for 2015 Escalade), 2012 Corvette, 2014 Ford Fusion, Previous: 2007 GL450, 2011
Yes this is a very minor problem BUT annoying......the light in the footwell on the front passenger side does not come on.......the owners manual does not list bulb specs for the interior lights, nor talk about how to get at 'em.....anybody know anything about this before I make a 60 mile roundtrip to the dealer to fix it? Thanks............
Old Jun 3, 2007 | 09:59 PM
carpersn's Avatar
2019 Volvo XC90 Magic/Amber, '95 E320 Cabriolet Midnight,'14 GL350 Lunar/Almond was '07 GL320CDI
i could be wrong, but...i think the passenger footwell light is part of the "ambient package" for which you have to purchase the leather interior...somebody else check this for me...
Old Jun 3, 2007 | 10:04 PM
blittle's Avatar
Yup....I have all of that and the other "ambient lights" all work......the passenger footwell light does not come on so I am assuming the bulb is bad and was hoping I could just pop the lens off and change it myself BUT I am not so sure about that.
Old Jun 3, 2007 | 10:39 PM
mbslk350's Avatar
2021 GLS450, 2015 E250BT 4Matic, 2007 GL320CDI, 2005 SLK350, 2001 SLK320
I may be talking out of turn since I don't have my GL yet. But the ambient lighting on my SLK350 is actually small LEDs, not bulbs. The GL's ambient lighting may also be LEDs, and that could explain why the manual doesn't show replacement bulb part numbers.
LEDs usually last a long time, so I'd be inclined to check for a wiring problem or open connection rather than a bad LED.
Old Jun 4, 2007 | 07:59 AM
blittle's Avatar
Thanks for the idea.......I have looked pretty carefully and it seems that the ambient lighting in the footwells uses the standard light ( about a 2in.long rectangular white plastic unit ) at a lower level ..... almost like a regular house bulb on a dimmer switch........anyway, that light fixture should light up at full throttle when the doors are opened and then drop to a lower level for ambient..... it does not do either. I don't have the guts to just pry off the lens cover...........so, I'll call for my appt. today!
Old Jun 4, 2007 | 08:58 AM
blittle's Avatar
Yikes! Talked with service......takes 1hr to 1 and half to disassemble the side panel and get to the light bulb! Off we go to service tomorrow.......
Old Jun 5, 2007 | 07:29 PM
blittle's Avatar
Well.....they were wrong......you simply pop the lens off (like I was afraid to do) and put a new bulb in. Took the tech about 2 minutes! Said it was the first one they have had......
Old Jun 6, 2007 | 06:04 AM
jpeardm's Avatar
13 SL550, 14 E63 Wagon, 15 S550, 11 M3, 08 F430 Spider, 12 ML350
Good deal, usually the other way around, a 2 minute job takes 2 hrs. You're all set again for some night time cruising with the proper ambience!
Old Jun 6, 2007 | 06:53 AM
blittle's Avatar
Absolutely......
