Open door indicator?
Have you tried it with any other doors other than the drivers door? Maybe the message you're seeing is for the drivers door only. Try shutting the back doors not quite tight & see if you get a different message when you close the drivers door & turn on the ignition.
Hmmmmm..........
Again.......doesn't make sense that they would have changed the programming so that it doesn't monitor the doors.....so maybe an error that needs to be corrected.
SOLVED! You are right on the money! The warning graphic for the 3 other doors comes on ONLY after you have moved the vehicle 10ft. or so. However, the verbal warning comes on immediately if it is the driver's door that is open and the vehicle is put into gear! Once again the value of the forum is priceless.........because my dealer is still trying to figger out how it is supposed to work
Thanks oknishThe Best of Mercedes & AMG
And, then donate the proceeds to Danno's Cancer Charity.
For the number of times ( with all sorts of vehicles ) over the years that I have solved my own problems when the dealer seemed clueless, I think we could fund a whole research project! Thanks again to you and Jen!
Thanks oknish
Thanks too, oknish!
