Bluetooth not working
Old Jun 19, 2007 | 10:13 AM
paulcars's Avatar
I have the puck and Verizon Razrs. The system has been wroking fine. Recently upon startup the ysytem cannot "locate" the phones and therefore does not work. I have unconnected and reconnected the puck with no change. Any suggestions?
Old Jun 19, 2007 | 12:53 PM
blittle's Avatar
2013 GL450 (traded for 2015 Escalade), 2012 Corvette, 2014 Ford Fusion, Previous: 2007 GL450, 2011
Have you tried working the other direction..........haveing the phone attempt to locate the vehicle? You will have to go to the bluetooth menu on the razr and work from there..........
Old Jun 19, 2007 | 04:48 PM
FireGuy's Avatar
GL 450
First try re-booting the phone. Sometimes Bluetooth just hangs on the phone end, especially if used with another Bluetooth device and then back to the MB.
Second, as the first writer suggested, initiate "headset" connection from the phone.
Once on my GL the phone Bluetooth hung and "crashed" Command on the GL - just froze it up. I had to turn off the car AND the phone to clear the jam. Long story short, I figured out it was the phone hanging, not Command.
Old Jun 19, 2007 | 09:03 PM
boxboss's Avatar
I had problems when the phone was not in the GL (or not turned on) when I started it. There is a ~30sec "window" when the GL will sync with the phone, and if the phone isn't in the car or turned on during that 30 seconds, they will not pair. After that time, and the phone is in the car and on, push the "TEL" button to pair them.
This may not be your problem, but it caused me some concern because my other cars will sync at any time, not just the first 30 seconds.
Old Jun 20, 2007 | 10:42 PM
paulcars's Avatar
Bluetooth fix
Thanks guys. For some reason the Razr Bluetooth power was off on the phone. Reset and all is well.
