GL450 Pulling a Boat
Old Sep 22, 2007 | 09:36 PM
gordongl450's Avatar
2007 GL450
Trailered a 25 foot pontoon boat about 80 miles today to bring it to the dealer for winterization and some servicing. The weight of the trailer, boat, engine, gas and stuff in the boat was about 4,200 pounds.
The suspension is really neat. When you hook up the trailer it pushes the rear end of the truck down. The when you start the engine the rear suspension pumps up and levels out the truck perfectly. Very cool!
Taking off from a stop, even up grades there is plenty of power.
Most of the driving route was highway at 65 mph.
The truck pulled the load very well. I was using cruise control and I could tell that there was a lot more downshifting as the truck maintained speed while going up hills. But it maintained speed fine.
Just a little sway, I wouldn't considered it bad. That big boat catches a lot of wind. It was a nice day, not too windy, but I had to concentrate on driving especially when I big 18 wheeler would pass.
I could not help but wonder how things would be different with the GL320 CDI? I wondered if there would be less downshifting to maintain speed going up hills while at 65 mph? I wondered if the take off from stops would feel noticably more powerful, because the GL450 seemed to do fine?
Anyway, it was a good experience pulling 4,200 pounds today.
Gordon
Attached Thumbnails GL450 Pulling a Boat-pontoon-front-crop.jpg   GL450 Pulling a Boat-pontoon-side-crop.jpg
Old Sep 22, 2007 | 10:29 PM
neodoc's Avatar
2017 Rolls Royce Wraith, 1999 CLK Cabriolet, 2023 Genesis G90
That's impressive. Does your trailer have electric brakes or those that are actuated by mechanical means? If they're electric, did you install the electronic brake controller on your GL? Inquiring minds want to know.
Old Sep 22, 2007 | 11:01 PM
scottybdiving's Avatar
2008 GL 320, 2007 Silverado LTZ C3500 Duramax Turbo Diesel
That is impressive looking, Although pontoons don't weigh a lot, they are like dragging a parachute. I assume it has surge brakes since electric brakes don't go well with water. I can't tell you how well the GL 320 will do. Even though it has a trailer hitch, the C3500 Duramax will see all the towing duties.
Old Sep 23, 2007 | 08:51 AM
2007 GL450
No electonics brakes. Just the mechanical brakes that are integrated with the trailer. They work well.
Gordon
Old Sep 23, 2007 | 10:40 AM
Nevada Jack's Avatar
2011 E350 Cabriolet..White and Almond Mocha
That second shot is awesome! The boat makes the GL look like a toy but a powerful one...:-)
Old Sep 23, 2007 | 12:25 PM
oknish's Avatar
'07 GL 450, '02 S 80 T6
That is so true, Jack. I had to go do a double take.
Glad to hear of your nice experience, Gordon. Did you get a factory hitch or you had one installed aftermarket?
Old Sep 23, 2007 | 04:14 PM
2007 GL450
oknish,
I had a factory hitch.
The only thing I had to search for was a longer ball mount.
On my Montero Sport the factory hitch sticks out from the bumper by 4 inches and is high off the ground. On the GL450 the factory hitch is deep to the bumper by 4 inches and is low to the ground.
Standand ball mounts that I could find measure 6 inches from the center of the pin hole to the center of the ball hole. If you use one of these the ball mounts on the GL the ball becomes VERY close to the GL bodywork and doesn't leave a lot of room for mistakes when you are backing up to hook up the trailer!
I went to a local RV Center and they had a longer ball mount. It measures 11inches from the center of the pin hole to the center of the ball hole. Then because the GL hitch is so low to the ground you mount the ball with the curve of the ball mount going upwards. Worked well.
Gordon
Attached Thumbnails GL450 Pulling a Boat-montero.jpg   GL450 Pulling a Boat-gl450.jpg   GL450 Pulling a Boat-6in-11in.jpg
Old Sep 23, 2007 | 08:55 PM
Newbie_2_MB's Avatar
2014 GL 450
Wow, that's a big boat! It makes the GL look like a toy. Glad to hear the GL did a good job towing.
Old Sep 24, 2007 | 12:29 AM
oknish's Avatar
Gordon
Thanks for the details, Gordon. They help. And from what I have heard the BU camera comes in real handy when backing up tp a trailer. I know I use it a ton when I have to back in to park and it helps a bunch.
Old Sep 24, 2007 | 10:21 AM
lkchris's Avatar
'10 CL550, '12 GL550
Probably worse without ESP.
Did you get any lights?
Old Sep 24, 2007 | 06:35 PM
2007 GL450
Ikchris,
Do you mean lights from the Parktronic due to sway?
If that was your question, the answer is no.
Gordon
Old Sep 24, 2007 | 08:20 PM
lkchris's Avatar
No, referring to ESP light, which is an exclamation point in a triangle.
You'll see it whenever a tire slips on snow, for example. It's in speedo.
Old Sep 24, 2007 | 09:28 PM
2007 GL450
ikchris,
No, I did not get any ESP lights. No problems towing the laod at all.
Gordon
Old Sep 25, 2007 | 01:06 AM
Love my GL's Avatar
'07 GL450
I agree...I pulled my Thule trailer 3k miles x-country without any prblms. Very capable vehicle.
Old Sep 25, 2007 | 03:11 AM
ReachWest's Avatar
2008 GL450 / 1999 ML320
Wow - that photo of the GL and boat in profile is awesome. Imagine you had to be pretty careful negotiating turns given the total length you were hauling.
Old Sep 25, 2007 | 09:34 AM
2007 GL450
RaechWest,
Yes, it is a long load and you have to make wide turns.
The GL450 was impressive pulling the boat. It was really smooth. I have to pick the boat up this weekend and bring it home, so I will do the same trip in reverse. I am hoping for clear weather again. We'll see how the return pull goes.
Gordon
Old Sep 25, 2007 | 10:05 AM
2007 GL450
Hill Assist Works Great!
One thing that I forgot to mention is Hill Assist. It is amazing. I have to pull the pontoon out of the water on a long concrete boat ramp that has quite a pitch to it. Not only the part of the ramp that goes into the water, even after you get out of the water the ramp is still going up hill.
Well, Hill Assist will hold the entire load for you after you put the truck in Drive and then come off the brake and give it gas. There is NO rolling backwards. It's great! My wife loved it because she is the one who is pulling the boat out of the water, because I am in the boat at that point. Rolling backwards on the boat ramp would make her nervous when we used to pull boats out of the water with my Montero.
Gordon
Old Sep 27, 2007 | 08:46 PM
tm4exc's Avatar
E320 & GL450
Does any one know what comes with the new GL's with installed factory hitch regards installing a trailer electric brake controller. I was at my MB dealer yesterday and they assured me MB now furnishes a 4 wire pigtail (like all US made tow vehicles) with a connector interface to GL vehicle electronics that can be used to integrate a controller. MY GL is due the second week in November and we still have some tailgates left. My Valley Odyssey controller is on order and has a kit with the four wires ready to go.
Old Sep 27, 2007 | 09:42 PM
2007 GL450
tm4exec,
I am not sure if this helps you, but my 2007 GL450 has a round 7 conductor trailer connector. I have a round 7 to flat 5 adapter to hook up my boat trailer.
Gordon
Old Sep 28, 2007 | 01:15 AM
StevethePilot's Avatar
2004 RX330, 2008 Scion xB, 2001 Honda Insight Hybrid, 2010 Toyot Prius v ATP
Gordon,
I've got something like that for my Excursion, but there's no cable between the two plugs - it's just one plug right into the other.
STP
Old Sep 28, 2007 | 02:12 PM
tm4exc's Avatar
E320 & GL450
tm4exec,
Gordon
Thanks. Need the 7 pin for electric trailer brakes. I read so much on this and other forums about the issues that customers had with the early 2006/2007 GLs where MB did not even run the 4 wires you need for electric brakes (gnd, power, brake light circuit and variable voltage from controller) back to the 7 pin receptacle. Apparently they fixed this in December 2006 in profuction. They then issued a TB in March of 2007 covering the issue. My question is trying to verify the statements by my dealer parts folks that MB now issues a pigtail (a connector with 4 wires) that plugs into the receptacle near the fuse box and will allow you to connect the 4 wires to your contrller. Not imperatvie to verify, but it would be nice to know.
Old Sep 28, 2007 | 03:42 PM
2007 GL450
tm4exec,
Glad to help. That is the extent of my knowledge on the hook ups. I don't know anything about how to use all the pins or anything about electroninc brake controllers.
Good luck. The truck pulls great.
Gordon
Old Apr 5, 2011 | 12:57 AM
will64278's Avatar
GL450
did you ever get the pigtail?
Was just wondering if you ever got the pigtail or did you just figure another way around the issue? I am in the same boat I want to add a electric brake controller but not sure if I need it with the factory 7 pin tow hitch plug. Do you still need a controller to work the brakes on a trailer?
Old Apr 5, 2011 | 01:52 AM
mdadgar's Avatar
2011 GL350 Bluetec, Irridium over Black Leather
It depends on the trailer.
Surge brakes (ie typical boat trailer) - no brake controller required.
Electric brakes (ie typical flatbed or enclosed trailer) - brake controller required.
I like this one:
http://www.tekonsha.com/content/prod...435&part=90250
Mounts to the trailer, not the tow vehicle.
- Mark
Old Apr 24, 2011 | 05:36 PM
desert-boater's Avatar
'07 GL450, '98 Wrangler
Great looking pic of the GL pulling your boat. I agree with your assessment: pulled our 21" SeaRay many times and never had a problem. But certainly can't beat Scotty's C3500 Duramax Power Diesel - you could probably pull a 35" with that thing ;-)
