Weird headlight issue??
08 S-550 & 08 GL-550
I have my headlights set to
auto but I just noticed while my headlights are on
so is just one foglight,, the driverside!
Is this a short or a setting issue??
Any input appreciated.... Thx
Directional fog lamps are part of the Bi-Xenon lighting package.
I don't have that package, but I thought the directional fog lamps only go on when you are driving and doing a slow turn to the left or right (not at fast speeds) and the the fog lamp to the side you are turning goes on for better illumination. Does this also happen when you are stopped?
dsunnym1, do you have the bi-xenon lighting package?
2008 C350
My wife's niece was pulling in our driveway the other morning as I was leaving for work. I had my wheels turned a bit and she tells me one of my foglights has burned out. I had to turn the wheel the other direction to convince her it was supposed to do that.
2008 C350
2008 GL 320, 2007 Silverado LTZ C3500 Duramax Turbo Diesel
It is pretty strange to view this from the outside. It definitely has the appearance that one light is burned out. However, from the inside, it is great. My driveway is long with multiple curves and the side-illuminating fog lights do just fine for our many foggy AM's.
hmmmmmmm......... Did not think about this. ![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
I think i need to check this out whether it is only when the wheel is turned?
Will update soon....
You could sit at a red light and turn your fogs off and on, one side after the other by using the turn signal- folks on the opposite side of the light would think your car's crazy or you are!
