Tire PSI?
Old Nov 2, 2007 | 10:38 PM
Evil Buddha's Avatar
GL 320 CDI
Question Tire PSI?
Just picked up a new GL 320 for the wife this week. What tire PSI are you guys running? Door says 32F and 38R. That seems a little low; it has Cont's.
Love the car.
Old Nov 2, 2007 | 11:24 PM
BeanCounter's Avatar
GL450 (Alabaster White/Black Interior)
I run mine at 34 in the front and 40 in the rear. It gives me a little "grace period" for any air loss and I have been told running a little more air pressure can get you a little better gas mileage.
Old Nov 2, 2007 | 11:32 PM
Newbie_2_MB's Avatar
2014 GL 450
I run the same as Bean Counter. I have a slow leak in my right front and in 13,000 miles, have had to fill it twice when the low pressure alarm went off.
Old Nov 2, 2007 | 11:45 PM
Jen, my tires have held the air pretty well so far. My only issue is that the check tire pressure warning goes off all the time when I get it near a cell phone tower (we have one in the back corner of my office parking lot). I am told this is to be expected. Oh well........
Old Nov 3, 2007 | 12:18 AM
2014 GL 450
That would drive me nuts! The pressure was at 26 when I checked it, so it was truly down. I just have to remind myself to check it every now and again.
Old Nov 3, 2007 | 11:27 PM
HoustonRider's Avatar
06 CLS500
if you look on the fuel lid, pressure is 32-F and 32-R unless you have a full load.
Old Nov 4, 2007 | 06:10 PM
GL 320 CDI
Thanks for the info.
Old Nov 4, 2007 | 07:54 PM
mbslk350's Avatar
2021 GLS450, 2015 E250BT 4Matic, 2007 GL320CDI, 2005 SLK350, 2001 SLK320
With that in mind, I set mine to 32-F and 35-R since I often have a partially-full load with wife, self, 2 dogs and a weekend's supply of cargo. I figured that splitting the difference between 32 and 38 would be an OK compromise.
Old Nov 5, 2007 | 04:14 PM
nantucketsleigh's Avatar
1992 500E, 2006 E500, 2007 GL 450
I run 35lbs all around. Higher pressure firmed up ride a bit with no noticeable harshness. I run same pressure all around to help reduce understeer.
