sunroof rattling
Old Nov 25, 2007 | 10:15 PM
smayshusband's Avatar
2004 E55 AMG 2014 GL63 AMG
sunroof rattling
I noticed a rattling sound when traveling over 50 mph. I narrowed it down to the rear sunroof. Almost sounds like static on a radio station. Any one else experience this problem on the GL?
Old Nov 26, 2007 | 12:02 AM
oknish's Avatar
'07 GL 450, '02 S 80 T6
https://mbworld.org/forums/gl-class-x164/218949-back-end-rattle-found.html
Old Nov 26, 2007 | 10:44 AM
blittle's Avatar
2013 GL450 (traded for 2015 Escalade), 2012 Corvette, 2014 Ford Fusion, Previous: 2007 GL450, 2011
Hope the above referenced thread takes care of your problem.........it cured mine
Old Nov 26, 2007 | 10:02 PM
I tried driving with the shade open and closed still heard the noise. Even had my wife drive while I sat in the back to listen, almost sounds like the glass roof is where the noise is coming from. We also hear it faintly in the front by the sunroof.
Old Nov 26, 2007 | 10:06 PM
mbslk350's Avatar
2021 GLS450, 2015 E250BT 4Matic, 2007 GL320CDI, 2005 SLK350, 2001 SLK320
Do you have cross bars on the roof rails? Those have been known to make some noise. Many folks here have removed the crossbars to eliminate some noise.
Old Nov 26, 2007 | 10:12 PM
No aftermarket Roof Rails just the factory ones
Old Nov 26, 2007 | 11:12 PM
oknish's Avatar
There is a felt wrapping around the sunroof and it has been known to get loose. If the sound is definitely coming from the sunroof, have the dealer check it out. Tell them to make sure that the felt lining is sitting correctly since that lining is supposed to insulate sound. Hope that helps.
