Great article on Diesel engines
This was helpful to me since I never owned a diesel and did not know much about it. Thought maybe some lurkers would find it interesting.
http://www.automobilemag.com/feature...ure/index.html
2008 GL 320 CDI
2008 GL 320 CDI Black/Black
2008 GL 320, 2007 Silverado LTZ C3500 Duramax Turbo Diesel
I disagree about their durability only being equal to a gas engine. Diesel engines are built heavier duty and achieve their performance with 30% less RPM's. It has always been common knowledge that they will outlast their gas counterparts. Why do you think they are used commercially?
1 Post
2004 RX330, 2008 Scion xB, 2001 Honda Insight Hybrid, 2010 Toyot Prius v ATP
BTW, re-watched "Shockwave" again yesterday. Whose crowbar was that out at Firebird? I love the fact you guys carry one. "Okay, got the tank and octopus, good mask, fins, you've got the defib and first aid kits, and ... oh, yeah, a big honkin' crowbar to beat the crap out of something should we need it. Ready!"
+1000 on that point, Scotty! Diesels are also about 50% simpler than the equivalent gas engine, even the new ULSD/CDI/Bluetec models. Fewer parts to fall off and go wrong.
1 Post
Oh, that's bull-hockey. I'll make my wife get the Land Cruiser and I'll keep my GL! Ha!
1 Post
Oh, this is so !
You've got your logic backward.
Engines are "built heavier duty" when their intent is commercial use.
Old GMC and International Harvester trucks came with heavy duty gasoline engines that were good for 400K miles, same as a diesel.
Diesel took over in trucks due to better economy and less maintenance.
There are indeed--see VW--diesel engines built specifically for car use and they aren't necessarily any longer-lived than gasoline engines built for car use.
I'd suspect our Mercedes V6 diesels to be as good as the gas V6s--which is pretty good.
But the engines with a longer stroke and higher compression ALSO actually HAVE that extra force. Commercial diesels are overbuilt. Consumer diesels may not be. Remember the VW Diesel Rabbits? They had tons and tons of blown head gaskets for example.
No (except for the old '80s gm conversion diesels) they aren't. The engines with 16.5:1 compression are built for 16.5:1 and the engines with 10.7:1 are built for 10.7:1.
The problems with the VW's were similar to problems the 70' - 80's GM diesels had. Underbuilt, which I don't think applies to today's modern diesels.
Diesels are able to have a longer stroke because the fuel burns slower and has more energy than gas. Longer stroke gas engines achieve more torque but reqire a lot more fuel, since gas burns quicker and has less energy. They also compromise RPM's, rate of acceleration, and horsepower.
But, you're making a correlation where there isn't one. There is no factual data to suggest that a MB diesel engine in the E, ML or GL is "overbuilt" such that it will last significantly longer than an MB gas engine. Maybe it will - maybe it won't. Forget about the combustion differences. The fact is that the longer stroke (which is required in order for the diesel to generate its torque advantage) presents more force on the crankshaft and main bearings - diesel or gas powered. Similarly, the higher compression creates valvetrain and headgasket requirements. So MB does a nice job and engineering for it.
That does NOT mean that they "overengineer" the same way that for example a Detroit Diesel is so that it can be expected to run for 800k miles. There have also been commercial gas engines which were so designed. The fact that they are diesel or gas is secondary. "Underbuilt", "well built" and "over-built" are three completely different descriptions.
The only way we'll know for sure is when we get a whole heck of a lot more historical data about them. For now, all we can say is that they seem well designed.
1 Post
2007 GL320 CDI, 2001 TJ Rockcrawler, 2005 Scoobie STI
http://www.thinkcuv.com/index.asp = Commercial
"Over-built" could be considered synonomous with inefficient like the heavy cast iron, naturally asperated versions. They were replaced by technology and superior perfomance in the 90's and they have proven to far outlast the comparable gas equivalents in their class.
My Duramax is just a much larger version of the 3.0L MB, physically and technologically.
