aftermarket LSD
Tx.
So, unless this vehicle shares the rear diff w/ something else, I'll assume that nobody makes an aftermarket rear LSD for this vehicle...and I suspect that a retro-fit 334 option is cost prohibitive...so it's a used GL450 if I can find one w/ 334...or off to Land Rover which I'm not entirely convinced is a great move.
BTW, I don't sell anything, you are free to buy whatever you want. I'm just a consumer who has owned two jeeps, three Land Rovers, and this GL in the past twelve years or so.
I also live where it has already snowed once this fall, so I winter drive about 3/5 of the year. Both my jeeps had lockers, and I find them pointless and dangerous in the snow. Limited slip? that is likely way better than a true locker, but there you are using a different principal, but the exact same effect through an electronic system. You only limit slip at the wheels instead of in the pumpkin.
Anyway, if you are sold on the need for a locker, the GL likely is not the right vehicle for you, because I have not seen or heard of any locker for this axle. I could be wrong though. All I know is I never had any problems in snow, or even almost two feet of mud and water in an open diff, AWD Land Rover, with momentum...
Or if you wanted to do it on the cheap, if you could find a wrecked 450 with the off-road package, you could snag those and put them in as well.
In the Jeeping community (to which I belong) there is all kinds of swip-swaping and modifying going on...
