FUZZY SPEAKER PROBLEM???
Old Dec 1, 2008 | 03:44 PM
ddcha's Avatar
2022 E53 SG
Day 3, and I have fuzzy speakers. Doesn't matter if it's radio, satellite, or CD player. Speakers have fuzz. Anyone have an issue with this? this is only day 3
Old Dec 1, 2008 | 04:33 PM
Television's Avatar
CL500 216
If the speakers have been overloaded even before you bought the car, the cone suspension could be damaged or the speech coils damaged
Old Dec 1, 2008 | 04:47 PM
ddcha's Avatar
2022 E53 SG
I guess. I bought it brand new with 6 miles on the odometer. It was working fine for the last 2 days, and we don't blast the music (can't be blown). Well, at least my salesman promised to come by with a loaner and pick up the car to make it right... just not a good feeling though..
Old Dec 1, 2008 | 05:49 PM
oknish's Avatar
'07 GL 450, '02 S 80 T6
My speech got fuzzy when large quantities of alcohol were poured into my body. Check your GL's alcohol level
Just kidding.
Old Dec 1, 2008 | 07:39 PM
dieseldoc's Avatar
2022 E350 Diamond White Metallic, 2016 GLC300 Dakota Brown Metallic
Just kidding.
i agree with nish. your Gl must have gotten a batch of e85. It is now very happy Actually, sounds like blown speakers that might need to be replaced.
Old Dec 1, 2008 | 08:35 PM
iluvmys65amg's Avatar
2008 S65 AMG, 2005 SLR McLaren
+1, I agree...Sounds like a blown speaker.
It's probably just a defective speaker from the factory, It should be replaced under factory warranty.
Old Dec 1, 2008 | 10:05 PM
robalo220's Avatar
2014 Black SLK 55 AMG, Black 2015 GL 550, 2011 Blue GLK 350
I had that issue once with my 08 GL 320. After shutting off and starting back up it cleared up. Happened several times with my 07 ML 320 also. Always cleared up after the next startup.
See if yours clears up the next time you drive it.
I think there are gremlins within.
Old Dec 2, 2008 | 08:25 AM
ddcha's Avatar
2022 E53 SG
Darn gremlins. You're right. It cleared up. What did you end up doing? You just let the gremlins be? Do they still stir up?
Old Dec 2, 2008 | 10:06 AM
LEOSOPHIE's Avatar
GL550
I had the same thing when new, went to the dealer with the problem in service driveway. Adviser started tapping around the passenger side roof and door area apparently where the fiber optics are located and it has been fine ever since. No other issues in 10,000 miles, love the car.
Old Dec 2, 2008 | 10:40 AM
ddcha's Avatar
2022 E53 SG
Did they have to open anything up? Where did they tap exactly?
Old Dec 2, 2008 | 03:15 PM
LEOSOPHIE's Avatar
GL550
No they opened the front door and tapped the top of the door frame. Static left now for 10000 miles, if that hadn't fixed the problem headliner was going to come down.
Old Dec 2, 2008 | 03:23 PM
ddcha's Avatar
2022 E53 SG
Thanks for the tip!
Old Dec 7, 2008 | 12:08 AM
robalo220's Avatar
Hasn't happened but twice. I'll try the tapping thing if it happens again.
Old Dec 28, 2008 | 02:28 PM
clausen's Avatar
gl550
Yep!Arrrggghhhh- day 365!
I have a GL550 and 2 door speakers and the front middle has been replaced. It is worse than ever! Any advice? I think it's electrical. It sounds tinney- front left and I have to fade to the rear with no sound up front.
