Snow tire sizing 2008 GL320 CDI
I am considering using 235/60/18 snow tires on it (which I already have a nearly new set of). From what I have read the factory 18" wheels are only 8" wide so the 235's will not be too narrow for the wheel. The change in rolling circumference is only 3% so speedo will not be too bad. Narrower tires should afford better snow traction. My only worry is that dry handling will be too compromised with the narrower tires.
Any opinions would be helpful.
Also does MB have a setting to calibrate the speedo to smaller tires like the VW's do?
I put in some Toyo open country 265/60R18 on my 2009 GL 320.
Great handling and snow/ice performance.
I dont know if its the 2009 model, but these tires handle and rides better than the all season Continental I had on my 2008 GL.
