COMMAND System Cycles Off & On at Will
Old Apr 17, 2009 | 02:16 PM
dariof's Avatar
2008 GL 320 CDI
Has anyone else heard of this?
While driving, my COMMAND system will simply turn off, then immediately turn itself back on.
When it does this, the following happens:
-MZB logo on COMMAND screen appears when the unit turns itself back on.
-Radio station goes back to the exact same station after a brief interruption.
-If I am using Blue-Tooth and talking to someone, the conversation is interrupted for a few seconds, but connection with the other party is not lost.
-The navigation screen is interrupted for only a few seconds, then the navigation "recalculates" the route I was tracking, and displays the remaining route (as usual).
The other day when traveling from Las Vegas to Carson City, this happened about 6 times or so. On the way back, it happened about 10 times.
ANY IDEAS? I have a 2008 GL CDI with 11,000 miles.
Old Apr 17, 2009 | 04:10 PM
StevethePilot's Avatar
2004 RX330, 2008 Scion xB, 2001 Honda Insight Hybrid, 2010 Toyot Prius v ATP
I'd say it's broke. Sounds like some kind of short, anyway. Never heard of anyone else's doing this (unless I missed a thread?).
STP
Old Apr 17, 2009 | 07:39 PM
Wolfgang's Avatar
MBs
Might be due to the voltage fluctuations mentioned in this recent dealer technical bulletin?
File Type: pdf
Old Apr 18, 2009 | 10:35 AM
Brocktoon's Avatar
GL 320cdi, Chevrolet Avalanchero, GLE 350 (on order)
Exclamation
I had the exact same problem, exact same model, and it was the glow plug relay causing overvoltage in several systems. Apparently there is a dealer advisory on it.
Have your dealer check for overvoltage codes.
Old Apr 18, 2009 | 10:42 AM
Brocktoon's Avatar
https://mbworld.org/forums/gl-class-...available.html
Old Apr 21, 2009 | 07:19 PM
Brocktoon's Avatar
Odd, this has just returened this weekend, now my COMAND unit is fried!
Old Apr 23, 2009 | 01:54 PM
dariof's Avatar
2008 GL 320 CDI
I noticed mine only does it when the navigation is "navigating." If I just have the map displayed (no voice directions, or working the other functions of the COMMAND, it doesn't do it.
Old Apr 25, 2009 | 03:02 PM
Brocktoon's Avatar
got mine back after a few days in a B class. It was the CD stacker sending voltage spikes down the bus...
Old Apr 28, 2009 | 04:38 PM
dariof's Avatar
2008 GL 320 CDI
Brockton,
I brought this thread and your post to the dealer this morning. They tested for the over voltage you spoke of, and found it.
The service advisor told me they ordered a glow plug module, and the car should be ready in a couple of days.
There wasn't much they could say, since I was armed with the knowledge you provided.
Thank you.
