Help! GL450 Drops Calls!
Here is how it happens:
1) I'm talking on the phone over bluetooth
2) I stop the car
3) Switch to the handset (on the phone), turning off the car mic and speakers
4) I shut off the car
5) open and close the dirver door, and the call drops
Help! Is there any solution to this - my other cars do not have this problem! I have the same problem with an iphone3G and a blackberry curve.
Not sure in your description how you are doing the transition, but perhaps try disconnecting the bluetooth connection....under the blackberry in the bluetooth setup, you click the menu button while highlighting the paired device.
Is the procedure that you are following what is recommended by the COMAND Owner's Manual?
I have locked my car and gone into my house (still in bluetooth range) and tried to make a call and my bluetooth is still connected (blue indicator on the phone) minutes after exiting the vehicle.
You will just have to play the game and get used to it.
Just yesterday I was in the service drive of the MB dealer ,car off ,standing outside of the car. A call came in. I felt it vibrate and had to select audio source on the phone before I could talk.
According to the MB technical information "once the car is shut off, the call will disconnect because the phone is paired with the vehicle".
Even though I've turned off bluetooth
UGH I am so upset - do they think this is a feature????
You can continue the conversation all the way back in the car. Start car and your bluetooth will pick-up. You will not hear the person on the other enx for around 10 seconds while it tranfers the call through to your command. When it transfers, you will be able to talk through the bluetooth and go about your way handsfree.
I do both scenarios every day and have never dropped a call or had any issues.
So.. I shut bluetooth off, change source to phone, shut the car off (still talking on phone). The minute I open the door the call is dropped.
Sounds lke I need to go into the dealership and have it looked at. If anyone has had this issue please please let me know! Thank you all so much
http://www.edmunds.com/mercedesbenz/...merreview.html
"I love new NAV, only problem so far I find, when i am on call through bluetooth, if i turn off the car and open the door it will drop the call, it didn't do it on my 2008 G35. that is only -ive."
I hope there is a solution!!!!!
STP
