Problem with GL 320 Diesel shutting down
As for "lemon law," the first thing to ask is - what are your state's requirements to meet the local lemon laws? If your vehicle meets these criteria, I'd start talking to the dealership about buying back the vehicle and reimbursing any extra costs involved.
That's where I'd start, if I were you.
the gl ergonomics make this scenario a very common occurrence.
the low common rail pressure is usually a result of clogged fuel filter (there is only one- sits in the v-ee of the engine just in front of the turbo). us diesel fuel is of very bad quality and filter usually is completely clogged by 20k miles.
alex
few cars
2. seen some bad fuel problems with filter being clogged due to
algae from bad holding tanks at fuel stations.
Does the Engine Crank but not start after it dies ?
How long has it been running for & what Fuel Guage Reads.
3. Fuel Pick up problem - Fuel tank has 2 sides & has been known to run out of fuel
with 1/2 tank or less.
What if any Codes ?
"P0087 fuelrail/system pressure too low"
The service department is close @ 1 pm today and Sunday. I already planned to bring the car to the service Monday but when I started the car the check engine light is gone...Should I still bring the car to the service without the check engine light on?
Just to let everybody knows that this happened to me before. The correction they did is "replaced crankshaft position senson": Part number 642 153 07 28 05 sender unit. Damage code : 15930347. written on the receipt.
In fact, as I type this, I am here at the dealer having my fuel filter changed....almost 20K miles.
Sometime this week, I'll change the oil myself.
Maintenance done for another 20K miles !!
Comments: " replace fuel low pressure fuel pump (in tank)
Parts MBN 164 470 20 94 28 and 164 470 02 30
My service advisor told me that they put in an updated fuel pump in the car.
Thanks!
"low fuel rail pressure" 120K Clears with Autel reappears after 20 or 30K. Only stuttered once on start other times OK. Never cut out yet.
What is cpc? thanks anyone, at this stage glad I have kept my S430.
